I have been shopping for a spray system that will create the least amount of overspray and yet give me the same ease of use and fine, smooth finish I have gotten from my HVLP and compressed air systems. I have looked at the Kremlin Airmix and an airless system but I have only used an airless twice and have never seen the Airmix in action. This makes it very difficult to make an educated choice. The system I purchase will be used to spray w.b. lacquers, shellac, pigmented shellac primer, oil based enamel, and latex paints. I am a one man shop and build and finish cabinets and fine furniture. Any help recommending or comparing these systems would be most helpful.
I'm not familiar with the aramix, but for the varied uses your'e talking about I would consider the airless. You can go from laquer to latex with a simple tip change, and you can build laquers very quickly. I have been looking at the new graco units. You can find a good one for about $500. The unit I now borrow is an OLD binks suberbee that still works like a champ.
*Brian:Kremlin Airmix is by far the best spray system I have ever used. It will spray just about any material imaginable, is easy to adjust, color changes are realatively quick and easy, it puts out a very small amount of overspray, is easy to clean and lays down a ton of material in a hurry. Plus, the finish quality is the best I've ever had. That being said, it does, have some drawbacks. First is cost--figure on spending at least $2,000 and maybe as much as $2,500 for a complete system. Also, because it puts out so much material, spraying pieces with a lot of intersecting corners (like insides of cabinets, chairs, etc.) can be a bit tricky. It takes a fair amount of practice to avoid a lot of runs and sags. I would say that if you do a lot of spraying a Kremlin would be a good investment. Since I switched to this system I figure I've cut my material use by somewhere between 20 and 30% simply due to the reduced overspray. However, I use one type of finish only and spray 300-500 gallons a year. If you use small amounts of a lot of different finishes and only spray occasionally, an Airmix system would be overkill.
