Making a craftsman door bell cover out of some beautiful lacewwod I picked up for free. Any suggestions on finishing?
I have finished w/ shellac before with great results but never on Lacewood. Is a penetrating oil a good option?
I’ve used lacewood several times as a veneer, and it is certainly a visually interesting wood.
I found that it was difficult to scrape, since the “flakes” are quite soft in comparison to the rest of the structure. For this reason I resorted ( reluctantly) to hand sanding. If working with solid wood, I’d try hand planing to bring out the maximum clarity of the grain, but since I’ve not done this, I don’t know how lacewood responds to planing .
The finishes you mentioned would work very well and even better in combination. A coat of oil to accentuate the grain, and shellac to provide a more durable finish and even out the texture, will result in a attractive finish.
Rob Millard
thanks, i will give it a try.
