I have floor molding around my HARTCO Pattern Plus “hardwood” floors. I believe the molding is finished with lacquer. The molding is OAKOVER a product that has a thin oak veneer glued to a pine based. This house is 4 years old but the molding finish seems to be flaking off in areas where the floor is being cleaned with a moist mop.
I believe, I need to change the finish to a more durable finish like varnish. After sanding the lacquer, can I apply varnish to the molding? Do I need to apply sanding sealer and then varnish? OR can I apply varnish over the lacquer? Thanks
Is Lacquer that susceptible to water? Or is it a thin finish?
Kerry, i assume this trim you are talking about is a shoe molding, correct. Was this molding a part of the floor manufacturer, or was it added by the installer and finished by the installer? Anyhow couple of things are happening here:
1. The finish is probably to thin
2. The back side wasn't finished, like it should have been prior to installation, shoe mold should be finished or at least sealed on 3 sides.
3. Be careful with how much water is left on mop, dont soak the floor, you should use only a lite damp mop.
To fix the problem is not easy, see if the floor is under warranty by calling manufacturer, if not, i would recommend installing new moldings. Make sure they are finished properly before installation and touched up as necessary after installation. email me if you need further advice...Good Luck!
Eric Hanick
Hanick Woodworks
