To make a bed rail appear thicker (6 feet long, 8 inches wide) I would like to laminate a piece of poplar (3/4 in thick) between 2 pieces of walnut, 1/4 to 1/2 inch thick. Is there a problem gluing 2 different woods together, as far as the wood movement is concerned?
Paul
Well, not much happens in the length direction so the only concern would be in width. I have seen a number of sail boats with tillers laminated with a combination of 1/4 inch ash and 1/4 inch mahogany, up to 6 or 8 layers. Now it's possible that these woods have dimensional changes that are closer to each other than walnut and poplar. Check a wood stability chart to be sure they are close. You can find a chart on the forestry service web site.
To play it safe, you can glue up the poplar only on the top and bottom, creating a hollow "box". That way you will avoid any possible conflicts between the 2 species. The box will be plenty strong. If you need tenons at the ends made from the poplar, glue them in also, but as separate pieces.
DR
That seems like a lot of work to avoid buying some 8/4 walnut, especially since you haven't addressed the issue of the poplar stripe down the center--pretty visible from the top I would think.
I think the stripe would look good, I always liked a contrasting filler for the visual interest. Kind of like teak and holly decks.
Since the house is on fire let us warm ourselves. ~Italian Proverb
Paul
Several years ago I built a walnut bed and had to do something similar.
I laminated walnut and poplar using epoxy.
Attached is a pic of an off-fall. I seen the bed a few months ago while measuring up for a dresser to go with it and the first thing that I did was check the rail to see if the laminate was still intact, it was. Don't know how long it will stay that way and not sure if it was a good idea at the time but so far so good.
Doug
Hi Paul,
I'd worry more about the grain orientation of the various pieces than differential rates of expansion and contraction among the two species; with the grain properly oriented and the glue-up properly clamped there shouldn't be a problem.
I made a bunch of cutting/cheese boards as Christmas gifts a few years ago. They were glued-laminations of five different species. There were slight differences in the rates of expansion & contraction that made it possible to feel a subtle shift in the heights of adjacent surfaces after the glue cured, but it was nothing to worry about.
Fortunately, I used a waterproof glue, as I found out only recently that one of the recipients regularly washes hers in the dishwasher - and it's still intact.
Good luck,
-Jazzdogg-
