I am designing and building a hardwood coffee table, simple design, hardwood top, 3″x3″ legs. My question is what is the best way to mount the legs. I was hoping to avoid using an apron or spreader. Trying to maintain a clean look. I realize I have to allow for the wood to move. I would appreciate any suggestions or ideas. I attached 2 images from my sketchup design.
Your design has to manage two issues - keeping the top flat, and coping with racking forces.
The easy option is to make the legs into squares and screw through them into the table top. You will need three pairs of screws each side of the cross-piece. A central pair and one at each end. Pairing will help with racking. Elongate the holes to allow for movement.
An alternative is to cut through tenons - these will often be wedged for effect. This is a harder option but will look better, but you will need to lose the lower piece or accept the possibility of joint failure due to wood movement in the top.
The youtuber's choice would probably be to rout C-Channel into the base of the top and fix it first to the legs, then to the top with threaded inserts.
As rob says, close the legs into full squares. Make the corners bombproof with dovetails or box/finger joints. Screws in center are fixed, outside sets elongated holes. To help with racking add an "outrigger" at the top of each leg pointing to center. A 6" leg with a bridle or M&T joint and a couple of screws into the top will help a lot.
Thanks for the input. I was thinking of adding a stretcher, it really won't be visible. Then either using slotted screw holes as rob_ss suggested or something like figure 8 clips. I also plan on using a tenon joint on the legs, I don't feel too confident making box joint or dovetail joints yet. I'm using pricey wood so I'm being cautious. I attached another image.
You can most likely also use figure 8 "desk top fasteners". I am currently working on a table which does not have aprons and the suggested way to mount the legs to the top are these figure 8 fasteners. You can buy them at Rockler - https://www.rockler.com/desk-top-fasteners
The way they would work is to imbed them into the leg by using a forstner bit to drill a shallow recess just the size to fit one side of the fastener so it is flush with the surface of the leg. The side that is screwed to the table top does not have to be recessed. The concept is that the the figure 8 fastener will rotate with expansion and contraction so the ideal way to install them is angled so the expansion/contraction will rotate them. They shouldn't be screwed too tight or I suppose they won't rotate.
There are YouTube videos on installation and, while there are some differences in actual process in each the concept is the same.
I would say, however, that a much better table construction - more strength and flexibility is to fasten the top to the apron and use standard rectangular table clips. Again, there are videos online about installation with these table clips and I believe Rockler also sells these with instructions online.
To date, I have used the rectangular fasteners with great success. I believe the figure 8's will work also, but have not used them till now. In the case of the table I'm making now, the look of the table is superior without aprons, so, based on other plans I've seen and the videos online, I believe it will work well. (Sorry if this is confusing. Watch the videos and it will be clearer.)
Familiar with figure 8 clips, but not sure what rectangular clips are.
So your table doesn't have an apron, which clips are you using? You wasn't quite sure.
I have several tables with metal hair pin legs, three screws per leg. They work well.
