I am tying to make dovetail joints for a large cabinet, 26 inches deep by 60 inches tall. I am using through dovetails with solid walnut lumber. I cut the tails with a dovetail bit and that part seems to work fine. I then scribe the outline for the pins, rough-cut the main portion out and then do the final trim with my router and a jig I built. The jig works fine as far as matching the dovetail angle of the pins but I can’t seem to set it properly and I have wound up with joints that have several pins that are too narrow. You see a small, even gap in most of the dovetails. As dissapointing as this is, I do not want to junk the large pieces of wood and start over again. Since this project is not being done for a customer I am content to try to fill the gaps in the joints somehow. I do not seem to get good color matching using the commercial wood fillers, so I tried mixing glue and walnut sawdust. That seemed to work fairly well on a piece of scrap wood. Does anybody have any hints about using this type of mixture for filling gaps. What proportions of glue and sawdust are best? What granularity of sawdust should I use (like do I use dust from my table saw or should I use finer dust from sanding)? Should I apply this type of fill after the joints have been glued and have dried? Thanks for any advice you can give.
If you slice wood from the edge of a piece that matches the one that needs fillers, you can shave them to fit, put some glue on the end and drive it in. Match the grain direction of what's missing and once it's sanded, planed or whatever, it should be hard to tell that you filled anything in.
Hi I like highfifh's method I do it quite often .It works real well.
Have a nice day Lee
Actually, it's not my method. I learned about doing it that way from Deneb, who demonstrates Lie-Nielsen tools, when I was at the WoodWorking Show last year. I'd like to claim it as mine, though.
Hi
It is a good idea whoever thought it up. No one ever showed me that trick. I used to repair lots of antique furniture for several dealers, Lots of those old peces of furniture had bad miters on the trim. So i tried filling in with small shavings, It worked.so one day i was messing around with dovetails and ended yp with a few gaps so i applyed that method to filling gaps in bad fitting dovetails.
Have a nice day Lee
Since dovetails have been around for a couple of thousand years, I'm sure there's no way to find out who did it first. My guess is that it was pretty close to the beginning.
Here in VA's Shenandoah Valley, I've had the chance to see many blanket chests, mostly made by the area's Germanic woodworkers. What I see a lot, is that the dovetails were deliberately cut on the loose side, and then wedged. This will definately reduce the "pucker factor" during assembly, but this pragmatic approach does not agree with our present day aesthetic which seeks perfection.
The pins were typically split down the middle with a chisel, and the wedge driven in to spread them until the joint was filled. When all the pins are wedged, the effect is not disagreeable.
Ray Pine
Yeah, I'll second that - Don't use filler or saw dust and glue. Instead make yourself some thin slices of wood and fill the gap by sliding these slices - covedred with a flim of glue - into the gaps. It will make a better looking and stronger fix. Done it more times than I'd care to admit! It works well.
Just to underscore what's been said - don't use filler but rather cut slips of wood from the same pieces, maybe even what you chopped out.
DR
Think I'll try the slice 'n fill approach. Seems like the best approach. Thanks for the tip.
Definitely forget about filling with glue and gunk. Wedges or slivers are the answer, and easy to do -once you have a suitable method for making them. An ordinary person should be unable to detect what has been done, and the joint will be strong.Nip them off with a chisel and sand if you like to sand drawer sides.Philip Marcou
Hey thanks for the pics. Looks great. That is definitely the way to go. By the way, I assume you put the gap filler chips inafter the glue up. You don't do a dry fit with chips and then glue up all at the same time do you?
J, for your specific project, I would glue it up with no glue on the gaps. If there are no clamps in the way then I would attend to the gap inserts-failing that then do it when all is dry and you have recovered from the glue up panic.
Er, the above scenario has never visited itself upon me.
When the glue is dry, I plane flush and inspect-any voids will then be most obvious and can be suitably matched with a wedge or sliver.
You may wish to look at my web site to confirm that I am not experienced in doctoring dove-tails: http://www.collectablefurniture.co.nzPhilip Marcou
Beautiful work Philip. Thanks for the advice. I suspect I will have to wait until the glue joint is completely dry before I set slivers to fill the gap. The dovetails I am struggling with are the kind shown in your military chest where the top and side come together: many pins and tails and somewhat larger than the drawer joints. After cutting the pins and tails my joints did not fit together. I had trouble determining where the binding was taking place because there were 9 pins and tails. It was difficult to tell if a specific joint was actually overlapping or just a tight fit. I think some of my gaps were the result of paring down the wrong pin. Thanks again.
I concur with others in regard to the best approach. In addition I'd suggest that you redesign this jig you made or learn to saw by hand. And in regards to filling those last little bits that don't get covered by the thin shims: Learn to use hot melt fillers. These are made in shellac, lacquer, or other stuff. Mohawk has several types that are easy to learn. The sticks come in a wide range of colors and can be intermixed. I have filled blemishes from wrongly placed screws (round hole) that are very difficult to detect. They take a bit of practice, but are worth it.
In the video that comes with the boxed set of Tage Frid books on furniture making, he has a technique where you take the slips of scrap intended to fil the gaps and tap them with a happer against something hard.
The idea is that the wood fibers will be crushed or compressed somewhat and that when driven into the crack the glue will cause them to swell back up tightly filling the void.
Just as soon as I make an imperfect joint I'll try it! LOL
David C
"Less than perfect" dovetails? Is there any other kind? (grin)
Not to be disagreeable, but wouldn't it be better to do them by hand? It sounds as if you will spend as much time adjusting and truing your jig system. For a piece the size that you are describing, and walnut to boot, I would think that you'd be better off hand cutting them.
I'm not a snob about this... I'd use a jig if I were doing production runs of drawers for example, but for a carcass that is 5 feet tall, handcut would be better I think, and probably less work. Whenever I do large cases, I tend to space the DTs farther than typically a jig would do and use fewer overall.
I realize the learning curve for hand cutting isn't trivial, but I believe that the time it takes to fiddler with a jig on a large piece is worse and the results less likely to be satisfactory.
Just my 2p,
Glaucon
