I am building a new garage that will go where my shop used to be. The new shop will be above the garage, on the second floor. Unfortunately this is on a flat lot so there is no ground level entry to the shop. The architect has proposed a trap door arrangement with a hole in the floor in the shop that can be accessed from the ceiliing of the garage. The problem: How to get heavy tools into the shop and projects out of the shop. I have seen other shops with such a feature, but cannot remember where. I need to set up either 1) a block and tackle arrangement or 2) a powered lift from the garage floor into the shop. The architect suggested a product called “auto attic” that is a 6 ft square powered lift. I cannot find any info on the web. Does anyone have any experience with this, or a similar product. Or how about a block and tackle arrangement. Any suggestions?
Thanks!
There are a number of car lift products that are less expensive than you would think. I saw a set up at a welders shop where he had a bench and storage on the platform, then he would lift it and work in that area. Worked great for him.
I used to work in a small furniture / millwork shop where they had made a lift from the parts of an old forklift. The forklift mechanism was attached to one wall of the shop and raised a plywood and lumber platform from the ground floor to the second floor. System was very powerfull and worked well. Just make sure that you have a fence around the platform so that things don't fall off as the platform is being raised. I have seen several useable forklifts sell for $1 - 2,000 at auction.
Jspieker,
My wife bought me the Tauton book last year that featured various shops. She and I both loved the shops with an oversized window...nice and bright. I'm just wondering if a set of french doors on the driveway side and perhaps a block and takle above would not do the trick. Getting the tools in you could rent a forklift and slide tham in the front.
The car lift things I've seen at surface parking lots in NYC...lift a car, park another underneath..kinda ugly and takes up a lot of space.
Most shops I have seen like yours have a trap door that hinges open, then above that is a chain hoist. Nowdays it seems that an electric hoist is darn near the same price as a chain hoist, but I suspect the chain hoist could be easily found in a pawn shop or on the Net. If you want the ultimate set up hang the hoist on a I-beam with a truck. This way after you raise the load you can move it the leingth of the I-beam to the desired location. You definately need to design for these features up front. The beam is heavy, but you can use it to support all the ceiling joists or rafters. If you don't use the beam you still need to reinforce the framing that will hold the hoist. The hoist should only cost $150 or so the cost of a beam and truck is harder to factor because you might need a crane to hang it, and at the very least it will change the design of the roof, but it should add around $600.
Fww #174 page 68 show one way of doing it. KDM
The Bill of Rights
December 15 1791
NRA Endowment Member
LEAA Life Member
CRPA Member
I worked in a stone cutters shop for years where all the heavy lifting and loading was done with a chainhoist/truck arrangement. Our loading dock was one floor down and covered by a gable ended dormer supported on posts. Hatch doors are tricky to balance wieght bearing and ease of opening. Bear in mind that the hatch will command the size of the largest assembly. For inspiration on lifting objects look into how hay was handled into the hay mow.
If I were to have a second floor shop, I think I'd want to access it from outside rather than from underneath via the garage. What if you are actually using the garage to fix a car or for some other project that makes your lift setup inaccessible? How about a deck off the wood shop with stairs to the ground and a trap door for big stuff. A chain hoist or electric hoist could be hung over the trap door from a beam that is carried by the same posts (extra long) that hold up the deck.
I have a second floor shop with stairs on the outside. I have never needed a lift, but it just a hobby so I don't have a lot of input and output, if you get my drift. My heaviest tool is the Jointer/Planer, which is 650 lbs. With the wings removed it probably comes in at about 450-500 lb, and I took only four guys to haul up the stairs with a cradle that I built from 2x4.
Good luck,
Todd
Hay bale hoist comes to mind.
Ah, youth! I remember when a bunch of friends was my default solution to moving heavy stuff LOL.
Alas, but all my friends are retired couch potatoes.
What do couch potatoes become after they retire?
Mashed Potatoes? LOL
If at first you don't succeed....kick it!
Seems like a hoist would be a better option than a lift, and less expensive I would suspect. If you are still in the build phase you could have an I-beam installed over the trap doors, assuming you have adequate headroom, and use an electric hoist mounted to a trolly on the I-beam, which would also give you some lateral movement as well.
I'd think this setup would be really handy well beyond simply getting machinery in/out of the shop... for example, getting large or heavy projects out of the shop when you are done with them!
