Recently completed new 40’x30′ woodshop (1200 sq. ft.) Floor is white concrete and the inside ceiling peaks at 16′ with 2×6’s crossing at 12′ above floor. I’m at the point of installing the lighting but I’ve got to tell you I’ve probably read 10 articles on the subject and dont really know whatkind of lighting or how much I need. T8,electronic ballast , high output, 4ft or 8 ft, any help sincerly appreciated here in houston,tx.
I just moved to a new house. And now have a 24' by 60' shop in a large storage building. Walls are covered with plywood that has darkened and regular grey concrete floor. Ceiling is 8' again dark wood. Originally there were 2 rows of incadecent light fixtures running the length of the shop. Bulb about every 8'. I installed 23w CFL's (100w equavillent). The lighting was ok but not great. Since then I have now installed 4' electronic ballast lights with t-8 bulbs rated at 4100k. I hung the new fixtures so they are in 2 rows 8 feet apart. Basically they are 5' apart (end to end) and 5' from the walls in the narrow measurement. They are 8' apart the long dimension. Made a big difference. I have those lights on 2 switches so I can turn on 1/2 if I don't need all the light. I am going to add a couple more lights where I have figured out I would like more light. If I were to do it again. I would probably space them 6' down the length of the building. They seem to put out enough light the narrow dimension. But I think I would like it to be just a little brighter the long way. Since your ceiling is taller. I would say go with the 4' fixtures in a 4'x6' grid (4' between ends, and rows 6' apart). They are very inexpensive, work well in cold and are energy efficient. K is the color of light. 5000k is supposed to be equavillant to daylight. The 4100k bulbs I got are considered cool white. When I need replacements I am going to switch to the 5000k bulbs. Will make it seem brighter. I bought the 4100k since they were about $12 a case cheaper (15 pack). But now realize the 5000k were probably worth the extra money.
