Hello everyone,
I’ve learned a great deal from reading other posts. This is my first. I am building a workshop attached to my garage 23×24 and I want to install sufficient overhead lighting. Ceiling height is about 10 feet. Any suggestions for the type of lighting you would recommend would be much appreciated.
Thank You
There was a discussion just last week on this site in answer to the same question, go to the bottom of this page click on the "next 50" icon and you'll find it under the general discussion list, dated June 15.
John
Thank you JohnW,
I appreciate you leading me to that discussion, I must have missed it.
Oddly enough, my answer to your question is based on your current age, and your plans for the future.
If you plan to stay in your current home (and therefore your planned shop) from now until you grow old, then there is no such thing as too much light. If I knew then what I know now (at age 47), I would have completely covered the ceiling with flourescent fixtures. (Seriously -- there would be lights almost everywhere.)
In addition, I would add some directional (incandescent) lights over the bench, and in the area that would be used for finishing. The directional lights can be used to cast those long shadows that show the minor imperfections in your sanded (or carved)pieces. Flat flourescent lights won't do that.
On the other hand, if this house and shop are only for the next few years, then get only what you need this week.
Thank You, I'm 51 and planning on staying put. Planning on giving life to many beautiful project in the shop. You are right,you can never have too much lighting.
DeaconDon,
To echo the others...never too much lighting ! Doing it again, however, I'd look to a solution other than florescents (sp?).....too many darn plugs required...and hard wiring makes them kinda fixed in position. Some kinda track lighting in a large loop around the shop that I could easily add different kinds of fixtures to would provide flexibility....and maybe some florescents in the center...
I've done some lighting design in my past and I learned early on that the surfaces of the space are as important as the fixture when determining fixture type and quantities. For example, if you have a white gypboard ceiling much of the uplight will be reflected downward. If you ceiling is exposed rafters then you will loose the reflective qualities. Also important is the wall material (light color - reflective or dark - absorbing). An economical solution is to get a nice general coverage with 4 or 8 foot flourescents (Electronic balasts) and add incandescent task ligting over work areas and around the machines. Don't forget about contoling the lights. The task light should be switched seperately to reduce usage and heat. Good luck with the new shop!!!
