I keep on hearing about some new “lightweight” MDF that is out and around
and while lightweight MDF sounds like an oxymoron to me I am wondering just
what is it I hear these people referring to. I’ve seen a 1/4’ hick veneered
panel a little while back that looked like it was on a MDF substrate but
since it was relatively light I’m thinking that may be that was what I have
heard people referring to. Just what is this? Is it called Lightweight MDF
or LDF (light density fiberboard) or is it called something else. And as
long as were on the subject is there such a thing a HDF ( high density
fiberboard) and if there is just how much does it weigh and what on earth
would anyone us
I first saw a sample of that lighter-weight MDF about 5 years ago. I believe it's made with fibers of western white pine, but I don't know that for sure.
Yes, there is such a thing as HDF--fiberboard comes in a whole range of densities. Here's an industry site that can probably answer your questions in more detail:
http://www.pbmdf.com/index.asp
*Light weight MDF does exist and it's a great product for some applications. It's trade name is TruPAN Ultralite. The material is made in Chile from radiata pine trees. It's texture and workability are pretty much the same as the MDF you are used to, but it's substantially lighter, so you don't have to have a friend help you lift a sheet onto the table saw. If you want to learn more about the product check out http://www.trupan.cl/. Hope that helps, Clay Baker, http://www.workingbetter.com
*Here in the UK HDF is used for laminated flooring, its a very hard wearing material.Hope this answers the QuestionDenny Kerrigan
*We have been playing with tru-pan for a few years in the university shop where I teach. Nice stuff, if you have the right application.Most tools hardly notice it. Very easy on tools. Cuts, routes, and sands with hardly any effort.Hates water. Don't EVEN try a water based finish on it. Will expand and contract with humidity changes.Will break easily. Find an application that put no bending stress on it.Very consistant in thickness, at least in my experience.The best use I've found for it? Experimenting on.Dave
*Yea it does exist, i just used some like everyone has said its just like reg. mdf but lighter and it does chip easier so be careful in handliing it especially after you milled it
*What it's about is...is not breaking your back lifting and moving it! Seriously though, we have used it in 3/4" thickness and it seems to machine the same,keeps it's edge etc., but it requires more finish appication, it seems to soak up more,requiring more coats.
