I received (some time back) a rockler rewards certificate for $100.00. Its about to expire so I thought I’d better log on and find something to buy. I had always wanted a moisture meter and found this one for $120.00. Anybody know if this brand is ok? I’ve never used one just but thought it would be great to have. Problem is I would not have a clue as to whats a good brand or a hunk of junk. (I really wish they sold LN) I’d bought something from them in a heartbeat. Anyway any opinions would be appreciated.
http://www.rockler.com/product.cfm?page=18085
Edited 12/31/2008 3:46 pm by bones
Six years ago I did a comparative test of six electronic meters and they all performed equally well, regardless of price. I would avoid the type of meter that uses probes as these measure only surface moisture. An electronic meter will sense moisture accurately up to about 1.5 inches in depth. If you put a 3/4" plank on a wet surface, it will read right through the wood to the wet surface. They also do not measure absolute moisture but relative moisture, but that's all we need anyway.
Bones,
Ligno is a very good brand that is not too expensive. As I have looked at the various models, they appear to be distinguished by the ruggedness of their construction....I'm basing my opinion on what I can see, I have no idea if the technology is better. The Ligno is tough enough but probably could not stand up to the abuse that some might see in the field being handled by several different people. You'll probably give it a very protected life...as I would.
I have a previous model of that meter. I've been quite satisfied overall and it's been working for over ten years.
Bones,
echo rick.
good meter. Mine has a second set of long pins that are inside it. Pain to change battery. I've had accurate surface readings that weren't far off from internal after resaw. As far as pin meters go, I think it's one of the best.Boiler
Thanks to all who responded. I figure what that heck. I ended up paying actually 28 bucks 8 tax & 20 difference so for 28 bucks If I'm wrong I've blowed more money on that on tools or jigs that did not pan out, but thats another thread. Funny part is the web site said oversold so it won't even be back in stock till the 8th. Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
You might check Hartville tool for the Ligno
http://www.hartvilletool.com
May still be on sale with free shipping. ;-)
Pat
Bones, one post above was somewhat incomplete in the info about pinless meters. A pinless meter needs very smooth wood to give an accurate reading. Pinned meters often include longer pins for deeper reads (as does the Ligno you're considering). I hope to eventually have one of each, using my pinned Delhorst J-lite for home use, and a pinless to use in the lumberyard. ;-)
BTW: the Rockler flier I got in yesterday's mail has the Mini-Ligno on sale for $99.99 -- if it's like the Delta feeder I'm after, it's a local store promotion, not a web thing.
Ya know I was browsing for something to buy and I saw your post. Unfortunately since I move from STL, I don't have a local store or the feeder you mentioned would have been mine! Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
I can assure you that an electronic pinless meter works just fine on rough sawn wood.It only needs a tiny contact area. Now, if you're talking about chain sawn wood, yeah, that might be a problem.
Interesting, different from what I've read over the years.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
