is there a correct way to align a 90* lock miter bit so you dont have to use a spacer on the fence? I have adjusted the height and the fence several times and cant quite get it right.
locked up on lock
Probably the most set-up sensitive bit to use. Use the lower left picture as a guide. The pieces must go together perfectly flush as you would want a glue joint.
http://eacmedia.net/manuals/shared/021.pdf
If you care to take the time. You can cut a shim for the outfeed side when running the vertical passes. It's better than running on the "knife edge" Using double sided tape to hold the shim ledge in place.
lock miter
thanks for your timely responce and pdf it helps greatly. dan nelson
