I’ve been asked to design and build a rustic looking reception desk. One of the specifications is that it have “log trim” as a design element. The design will incorporate half logs(split lengthwise) as columns every 4′ or so across the front elevation. At the top of each column, the log will turn at a 90*angle so that a full round end grain section will jut out not unlike a corbel.
Does anyone know of a source for clean, kiln dried logs? I’m looking for about 6″ diameter at any length over 3′ long. I only need a small quantity-maybe 50′ total. Pine would be the first choice. I’ve searched under log home builders, and log trim without a lot of luck.
I’m trying to avoid taking square stock down to round to make my own. I will do this as a last resort, I’m afraid it will push the labor cost a little too far out.
Thanks in advance for any input.
-Paul
Paul, I think what you want to search for are "peeled logs". This company may have what you want.
http://www.akerwoods.com/
Exactly what I'm after. I'll call them in the a.m.
-Paul
Paul , Peeler cores would be perfect . Also from your local building supply yard fence posts come in different diameters 6" should be available .
good luck dusty
Never heard the term "peeler cores" before now. That's probably why my supply guy didn't know what I was after. I thought about fence posts, but I couldn't locate any that were dry.
-Paul
A peeler core is what's left over after they run it through a veneer mill and strip off all the veneer they can get. I'm not sure, but I doubt they are really "dry". If you need/want them dry, you may want to put a moisture meter on 'em and, if they aren't dry enough, take them dowm to your local mill and have them put them in their kiln for a spell.
Mike HennessyPittsburgh, PA
Thanks for the info, Mike.
-Paul
Hi Mike,
Wouldn't these peeler cores end up being primarily pith from the center of the log?Bob @ Kidderville Acres
Use whatever tool needed to Git 'r Done!
We used to use peeler cores for fencing horses. Truth be told, I didn't know you could get the untreated -- ours were always treated for rot resistance. Amazingly enough, they tended to stay straight and true.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thanks for the response. My boss ended up getting what were essentially fence posts that hadn't hit the pressure treating tank yet. They would not have been my first choice. They were pretty wet when we milled 'em and although the project called for rustic, I'm afraid they will check and twist a little too "rustic" once they dry out. We'll see......
Thanks again,
-Paul
Hi Pablo ,
I know your boss already got some fence posts to use but ,,, another product that could possibly be used for your application is what is called Log Cabin siding . It comes in several different sizes and is usually ship lapped , and should be dry and stable .
regards dusty
Thanks for the info, I'll file it away
-Paul
