This is a follow-up to an earlier post of mine where I inquired about how to make a Star Joint. I’ve learned, thanks to a member of this forum, that what I’m referring to is actually called a long splice joint and is used in making pool cues. I’ve also learned that many of the joints used on cues that resemble this joint are actually done with inlays and are not a true long splice joint. I am seeking the knowledge needed to be able to make a true long splice joint. Any help on where I may obtain that information is much appreciated. Thank you.
I believe what you're referring to is also commonly called a "scarf joint." I have a few different joinery books that refer to them. Though I haven't done one myself, they are more commonly used in carpentry. The Japanese joinery books have many, from the simple to the ridiculously complex. I'm sure a Google search will help you out.
Thanks!
Thank you for this information.
Mrossk is correct
I have cut a few of these along the way and quite a few years ago. I believe the ratio is 1:12. 12" of length for every inch of thickness. Just layout the angled lines on both sides of the ends of the pieces, you maybe able to rough cut the angle on a bandsaw depending on the size of the timber, and then finish up with a number 7 or 8 jointer plane, cutting to the lines. You will need to back up the end being cut on the bottom as you will be planing to a feather edge,
