Hoping to build the desk designed by Lonnie Bird in FWW 154,155,156. Most of the dimensions are straight forward. I was just wondering if any other readers have built this piece? I’m just a little puzzeled with the pigeon holes and the gallery work presented in 155. Any inputs would be great. Dan
HI danmart,
I have been building two of the secretaries and I am currently in the desk gallery stage (phase?). What question did you specifically have, maybe I can help?
Edited 12/21/2005 11:11 am ET by BOBABEUI
I think I am going to build the Bird desk/sec in FWW 154-6 in the next year or so and I wanted to communicate with someone who is doing one or has completed one just to ask an opinion on a couple of things.
1. Did you buy the bit set to cut the moldings and the raised panel profile?
2. What is the number of the set? I seem to remember Bird giving the number of the set in an old issue of FWW stating the price from CMT.
3. Not sure about mitering the door panel frames as opposed to coping?
4. I ordered the hinges needed for the offset doors from Ball and Ball and that was easy.
Have you completed a desk/sec already?
Any help would be great
Dan O'Sullivan
Durham, NC 27705
Hi Dan,
Here are the answers to your questions;
1) Yes I puchased the CMT router bit sets suggested in the FWW article.
2) Two CMT set were purchased #800.524.11 Lonnie Birds Small arched door set ($160) and 800.523.11 Lonnie Birds Crown Moulding set ($320). I also purchased a CMT panel Rasing bit 890.502.11 for 5/8 inch stock (upper toomstone panels).
3) The upper door styles and rails were done just a Bird suggested, mitered thumbnail moulding.
4) Hardware from Ball and Ball ($$$$$)
The two pieces are Wedding gifts that should be ready for the couples fifth aniversaries :-).
Best of Luck and Happy holidays.
What was the toughest part of the project for you? Was the gallery complicated or was it straight forward when you got started?
Well I just finished a windsor chair and I'm heading to the FWW/Colonial Williamsburg Symposium in January. Its a whole lot of fun to get up there with some woodworkers and talking about projects.
This year I'm going to see Curtis Buchanan do his thing in the first session.
Thanks for the reply
Dan O'Sullivan
Dan,
Actually, the main structure of the galley is straight forward.. You can actually dry assemble the whole galley deal without any glue, the combination of the stopped dado's and with the vee-grooves really works out well. After you get everything figured out in your mind it goes pretty well. I used lots of templates and test cuts, because it really takes guts to start cutting dado's in the inside of the semi-finished case, one woops and it's all over..
I am a really, really slow builder, job and family has only made the situation worse. I figure the way I work I have another year of building to go.
Best of luck..
I applied a little gamma correction to one of your snapshots, reduced its size, and saved it as a jpeg file (attached).
You can download free photo software from http://www.irfanview.com that will allow you to do the same thing.
-Jazzdogg-
Jazz
I use irfanview all the time, but when I try to save a pic like those above I dont seam to be able to get them to jpeg, how do you do that part.
If there in bitmap I'm usually screwed, no matter how small I make em, there still huge!
Is there some trick that I dont know?
Doug
Hi Doug,
I open the file, make my changes to the photograph, then click <SAVE AS> and select jpeg as the file extension I want to use.
The changes to the photograph (file re-sizing, gamma correction, sharpness, etc.) are made under the <IMAGE> pull-down menu.
-Jazzdogg-
JD
I was saving a bitmap to my pictures thinking I should be able to convert it to jpeg in the transfer to my computer.
I tried one and did the conversion with irfanview, worked like a charm!
Doug
wow. thats just a shot I took of a desk I made years ago with limited light. It seems funny to see it "fixed" up and being looked at by other folks.
Nice
Dan
I'm also making a desk based on Lonnie Brid's articles. I am making some changes to his design though. Most importantly, I'm using cherry. I also decided to make cock beaded drawers instead of Lonnie's profile. And I changed the gallery to suit my tastes. A desk like this takes a LONG time to make, and the fact that my shop is 12' by 12' complicates matters. That said I hope to be done with the base by March, which is one year after I started it. Right now I'm making the drawers, and prepping for my first attempt at veneering. I'll attach some more pics soon.
Attached are some pictures of the work in progress.When people 100 years from now see my work, they'll know I cared. --Matt Mulka
I have a question regarding technique on this. I have seen how the horizontal drawer runners attach to the sides by a dove tail joint. How do you cut the dove tail on a long piece such as a horizontal drawer runner? Do you do this in a router table with the drawer runner held up vertically? Thanks
I use a horizontal router table made from the plans in FWW #147. I think a hortizontal table is much superior in many applications.
I built one of Pat Warner's jigs to make the dovetails on the horizontal drawer dividers, it's here http://www.patwarner.com/dovetail_tenoner.html. Got to say it worked really well, the ticket is to use a genune De-Sta-Co toggle clamp not a knockoff.
Best of luck
