I am trying to build up a slot cutter bit for my router table. The shaft, and arbor is .5 in. The slot cutters are also .5 in. I just need to vary the spacing between cutters by a few thousandths. I have a small spacer less than .25 in. I have not been able to locate a shim kit for this size shaft.
Thanks.
Clement
You can always make your own using paper of different thicknesses.
David Ring
http://www.touchwood.co.il/?lang=e&id=1
Go to http://www.mcmaster.com and type in 90805A182 for peel away shims.
Edited 5/25/2009 2:13 pm ET by RickL
First link had typo in it, try this:http://www.mcmaster.com
Those are cool.
Edited 5/25/2009 11:40 am by forestgirl
