Anyone know where I can find a nice Bow Saw? I have the issue of FWW that shows how to make one but I would like to see what it would cost to buy one also.
Dale
Dale
Try Highland Hardware
Possibly not of interest, but I found that Roberts & Lee, the London (England) sawmakers still make bow saw blades in sizes from 8in to 16in. They also make pad saw (keyhole saw) blades, too.
Scrit
timber
http://www.highlandhardware.com
Danish Bowsaw $39.99
Contintental Frame Saw(large bowsaw) $39.99 4 differnt teeth setting.....
sarge..jt
Timber,
In addition to Highland, Woodcraft carries Frame saws too....or just blades at $4.99 each and you can build your own. I made one a couple of months ago using some scrap maple..fun little project...you don't really need plans, most of the dimensions are dictated by the length of the blade and how it's connected to the end handles.
Thanks guys, Do any of you use one? If so how do you like it?
Dale
Hi Timber
I do use a bow saw from time to time, an older one stamped with the maker's mark "Nurse" (a London tool seller of years gone by). They are pretty easy to use and don't require too much effort - they can also cut 6 to 8in thick stock - try that with a power jigsaw - so they have their uses. I always take one out with me when working on site - nice thing is that they can be broken down and packed flat in a minute or two and if the string breaks it can be knotted (continue until knot:string ratio exceeds 1:6.....). If you do get one just remember to point the blade to cut towards you on the pull stroke.
Scrit
I don't have a bandsaw so I rip wide flat pieces on the TS with the blade at full height, both sides and finish up with the frame saw...it works. On smaller pieces I can use it to resaw but I'm having a problem with tracking straight...
For everything, beats a back saw hands down for dovetails and other hand cut joints. They are so easy to make, you can have ten or more for the price of dovetaile saw.
Highland and Garret Wade sell the blades...and I can't think of anything simpler to make out of scraps. Buy the blades, eyeball the proportions, and have at it.
http://pic3.picturetrail.com/VOL12/1104763/2594266/31846134.jpg
http://pic3.picturetrail.com/VOL12/1104763/2594266/31846102.jpg
http://pic3.picturetrail.com/VOL12/1104763/2594266/31846085.jpg
Look in the Gallery for more detail on how they are constructed.
Edited 11/2/2003 10:40:33 AM ET by Bob
Bob
Thanks, those look very nice. I do think I will make my own from some nice Birdseye or Curly Maple. I also will purchase one to try out for awhile and use it as a guide to how I will make one more personal.
Dale
You can always make your own blades too. If you can get a hold of some broken band saw blades, just go to a local welding shop and get them to tack a couple pins on them and you are set to go. That is the plan that I have in mind. I just haven't gotten around to making the saw yet.
derek
I have made them from bandsaw blades, you do not need pins, just use a nail to drill pin holes in the ends of the blade. A blunt soft nail will remove the temper and go right through. I went on a bowsaw kick after meeting Tage Frid and now use them for everything, including dovetails.
The blade on both British-style and European style bow saws isn't pinned. It is punched-through and the blade holder, a turned brass pin with a slot cut in it for the blade, is also drilled-through from the side. To hold the blade simply pop it into the end of the holder and push through a small panel pin. Much easier than welding pins on
Scrit
