Looking for a good wood filler for cherry.
Does anyone have a suggestion for a good wood filler for cherry that will accept aniline dye?
I believe in the US
it is called plaster of Paris, here in Mexico it is called blanco de españa (white of spain). Mix this with yellow or white glue and some cherry saw dust with water, it will take any stain after you have mixed it and it dries very hard so you can sand it. I don't have exact proportions but I mix about half a cup of plaster, about 2 tablespoons of glue and the rest is enough water (not too much) to make a thick enough paste you can spread easily but will still hold even upside down. You can add the stain at the moment you have the paste or when you are filling, it takes a bit of practice to get the exact match but it works wonderfully.
http://www.woodcraft.com/Family/2020580/Timbermate-Water-Based-Wood-Filler/videos.aspx
Scroll down to see video.
Finish first then fill with shellac sticks. These are melted in with a hot knife. You can achieve a perfect color match.
Ditto timbermate
I'll ditto timbermate, A little stinky but sure works great, and can be used as a pore filler if you want.. Dries very quickly.
http://www.eagleamerica.com/prod_detail_list/s?keyword=timbermate
For cherry, my usual filler is epoxy tinted dark black with fresco powder, to simulate resin.
I've never been able to guess in advance how a wood will look after dye and first coat of finish. If your guess is wrong, you can color with dewaxed shellac and fresco powders, using a fine artist brush.
