I am finishing the top of a cabinet that has birch plywood with a maple edge. I am trying to match a stain that is on the order of cherry in color. Do I need to worry about blotchy stain on the birch? Secondly, the top of this cabinet is at about 40 inches high. I want a satin, durable finish. I’m thinking of either Verathane Diamond polyurethane or General Finishes Top Coat.
I would prefer to use waterbased finish. I will be brushing or wiping, not spraying the finish. I don’t want to break the bank.
Is there something better that I’m overlooking?
Actually, depending on what type of stain you use you'll likely get blotches in the birch and the maple.
What type of stain are you going to use?
I am open to what kind of stain, in an effort to avoid the blotching. What do you recommend?
Cut some Zinssers seal coat (dewaxed shellac) in half, wipe or brush on a light coat sand lightly with 320 then stain. You can try a gel stain but a barrier coat is more reliable.
