I’m still new in the dicussion groups – sorry if I posted this in the wrong place.
I’m looking for the article on removing brass finishes from hardware. I believe it was dipped in acid or the like. Does anyone know where this article is? Thanks, Ron
Remove the hardware and soak in lacquer thinner or muriatic acid. Rubber gloves and good ventilation is required. Birchwood Casey brass black is avaible in many gunshops to patina the cleaned off brass.
Edited 8/31/2005 9:03 am ET by RickL
Edited 8/31/2005 11:58 am ET by RickL
You probably mean soaking in lacquer thinner, not lacquer. Most bright finished brass is coated with lacquer to prevent tarnishing, so removing the lacquer is the first step in antiquing the brass.
John W.
Oops! Correct. Did a lot of this type of work when I worked as a metalsmith. We redid a lot of hardware and made lamps and all kinds really interesting stuff.
Thanks to all - that really helps. I'm trying to get away from the bright brass look and a bit more craftsman style. Any idea what I might expect to see in terms of metal under a Schlage lockset? Mucho gracias from Arizona!Ron
Edited 8/31/2005 12:35 pm ET by cactusron
Unless it's a real expensive one it's going to be brass plating over steel but it can still be patinated. Actually they coat them with something stronger than lacquer but the acid or lacquer thinner will work. The acid is quicker. Get some Birchwood Casey and experiment. Scotchbrite will be nice to ajust the tone of the patina. I'm sure you've seen some of the Schlage handsets with the brushed bronze look.
Thanks Rick,I'll give the acid a try this weekend. I'm going to use it full strength and not remove the lock mechanism. Hope that's OK? I'll then finish it off the way you suggested.I'll let you know how it came out.Thanks again,
Ron
FWW Issue 121 (Nov/Dec 1996) has an article about antiquing hardware by Gary Rogowski.
