Hi all
Looked at a cabinet job today.
The owner had cabinets with pull out shelves and wants me to make more for a Pantry.
The cabinet has a typical shelf standard (the common type) mounted inside.
The shelf is a simple piece of wood with another slide out shelf on top.
So far, no problems.
Here is where the problem comes in, the shelf can be adjusted up or down on the standard to accomodate different size pots and stuff.
The shelf has a small clipp (kind of like a key) that goes into the standard to prevent the shelf from tipping when pulled out.
I’ve never seen a clip like it.
Anyone seen this and know where I might find them.
HI Jeff accuride makes a clip for there slides and so does kv ,Ill get the product # for you tomorrow night, I have a few left over from a job, there not cheap, almost as much as a pair of slides. mark.
Mark
Great, thank you.
I was afraid that it was something discontinued that I'd never find.
It did'nt show up in any of my catalogs.
This will save me having to brainstorm a replacement.
I'll wait to hear from you.
Thanks again
HI jeff, the accuride catalog #5701 the order #is 4180-0100xe
the phone#(562)903-0200 I would give them a call to see who sells this product in your area. good luck mark.
Great, Thank you.
I'll give them a call
