I need your help. I an building a swing lounger that utilizes antique finish marine grade brass finished hardware but I can’t seem to locate the one I’m looking for.
Please see photo attached. If you know of a resource where I can find something similar, I would appreciate. Yes, I have searched through several marine hardware web sites.
Felix in Miami
Hi Felix ,
I'm just grasping at this for you but ,,,
The pin that goes into a wooden gate post and attaches to the gate is a similar looking piece of hardware without the " S " hook .
The gate pin is mounted horizontally but in this case you could place it vertically into the frame .You may need to drill a few holes in the pin to through bolt or screw to the wood frame .
Otherwise a eye bolt the correct size will also work , maybe you could paint it Brass if need be .
hope this gets you looking at what is available easily
regards and good luck dusty
Do search for Duckworks, an online magazine/store
If you have no luck elsewhere, I've always had great success talking to the folks at Fawcett's in Annapolis. Send 'em your pic and see what they say.
http://www.fawcettboat.com/
Mike Hennessy
Pittsburgh, PA
Everything fits, until you put glue on it.
You might give Jamestown Distributors a look and also West Marine.
Google will get you there.
You want bronze hardware, not brass, I think. A google for Bronze Eyebolts reveals some possiblities. Here is one:
http://www.tendercraftboats.com/fasteners.html
Unfortunately, I've had to become capable of finding marine hardware. Last thing I had to find was a cast aluminum gooseneck.
Edited 6/3/2009 1:57 pm ET by SteveSchoene
eye nut:
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/25430/377%20710%201788/712//Primary%20Search/mode%20matchallpartial/0/0?N=377%20710%201788&Ne=712&Ntt=&Ntx=mode%20matchallpartial&page=CategoryDisplayLevel1&Nr=AND(Record%20Type:PRODUCT,Store:WESTMARINE)&isLTokenURL=true&storeNum=2&subdeptNum=323&classNum=457
U hook
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/8312/377%20710%201788/712//Primary%20Search/mode%20matchallpartial/0/0?N=377%20710%201788&Ne=712&Ntt=&Ntx=mode%20matchallpartial&page=CategoryDisplayLevel1&Nr=AND(Record%20Type:PRODUCT,Store:WESTMARINE)&isLTokenURL=true&storeNum=2&subdeptNum=323&classNum=10905
