Hello everyone. This is my first post here. I attempted to search for my answer, but could not find the information I was looking for.
I am trying to figure out a good lubricant to use on the height adjustment screws (if that is what you call them) on my planer. It is a Jet JWP-13dx and the height adjustment screws/rods are exposed. I would like a dry lubricant to not attract dust. I was thinking silicone lube. Would this be correct? Thanks for any replies!
lube, no lube
I'm not familiar with the model of planer you have, so I might be talking through my hat here. But, I'd check the manual and/or make contact with Jet customer service. It may well be that they are using a design that doesn't actually require a lubricant, such as a nylon or UHMW plastic bearing surface.
silicone lube
I sure don't know but I am usually wary of getting silicone on or near any wood that has to be finished.
jig A loo
This is a new product I came across on the central coast of California in Grover beach. It is a silicone base product, but if used on the acme screws you should be fine. As on any tool the use of a silicone base product should be place in selected areas. On a planer or a jointer it should present no issues. As you work any wood to the finish product, one will be sanding and any residual will be sanded off.
If you do use this on a table surface make sure its completely dry before you place a board on it just to be safe. I am currently experimenting on my job site saw with this product on the top and so far the results are good. On the central coast the dew can on the Bosch table saw which is aluminum, can grab the wood. This product has eliminated this, so far so good.
http://www.strangenewproducts.com/2006/10/jig-loo-spray-lube.html
Simple is good
An old tried and true method that still works is paraffin. And everybody has an old candle laying about.
And if you want to make it even better. Melt the paraffin and add a lot of powdered graphite and let it solidify in an appropriate mold.
Do this in a double boiler !!! NOT directly on a stove burner.
