On pg. 35 of FWW 223, there is a very interesting lumber rack using 1 1/4″ angle iron. I have looked
through the article and a small print plan on the FWW site, but I cannot find any mention of the lenghth of the
angle iron pieces. I know the angle iron is strong but I wonder how long a piece I could use and how much
weight it could hold. Anyone built this rack? Any idea how long the iron shelves could be?
Jr
shelf depth
"About this long," he says, holding his hands up with the palms facing each other. ;-)
! 1/4" angle "iron" will hold several hundred pounds, I'd guess, before it starts to bend. It's more likely that the grain of the support studs would start to crush before the angle iron would actually bend. Soft wood studs would be more susceptible, of course. I didn't see if the article mentions the actual material, but I'd be concerned about iron staining the wood unless it was painted appropriately. Stainless angle might be better.
Hot rolled mild steel angle runs about $2 per foot, compared to about $6 or $9 per foot for stainless, depending on the type selected. (at onlinemetals.com)
Ralph,
I did not think about the iron staining but , that's a good point to consider. I would not by SS angle for
this purpose, so I will consider painting. I must admit I wondered about the 4 X 4 lumber and thought
the same about strenght. I know it is hard to tell in the pictures but I would lean toward the material being
Fir or some softwood. thanks.
JR
A guy (or gal) needs one of these
You can look up stuff like that in this book. (a many years old version would be just as useful and much cheeper at the local used book store).
http://www.amazon.com/Machinerys-Handbook-29th-Edition-Toolbox/dp/083112900X/ref=sr_1_1?ie=UTF8&qid=1345167344&sr=8-1&keywords=machineries+handbook
Though of course when you add angle bracing the thing gets much stronger.
PS: here is an old copy for about six bucks
http://www.amazon.com/Machinerys-Handbook-Guide-Tables-Formulas/dp/0831125993/ref=sr_1_4_title_1_har?s=books&ie=UTF8&qid=1345167926&sr=1-4&keywords=machinery%27s+handbook+27th+edition
Thanks roc, I just ordered a copy. I knew there had to be a source for such things but
didn't know where to look. My son will probably enjoy looking through it as well, he has an
interest in all things mechanical.
JR
It comes in handy and ends arguments
How fast should I turn this size bit in this particular material
Tons of formulas to figure about anything out
What size drill bit to use before I tap thread a hole.
What coolant or lubricant to use when drilling "exotic" materials. Brass, cast iron, aluminum, stainless steel, titanium etc
How much torque to put on various strength grades of fasteners. For both dry thread and lubed thread !
Strengths of all the grades of load bearing chain
on and on
sharpening geometry for cutting all materials in the various ways
the sort of thing a true nerd can curl up with for hours and that can bore the average person to tears.
If nothing else it is a big/little thick book and can be used to prop the door open.
Machinery's Handbook . . .
. . . don't stay home without it. ;-)
A great resource, to be sure. That, and a Starrett full-line catalogue can make a fella complete. ;-)
