I have really been getting into handplanes for their simplicity and reliability. In reading up on how to tune-up/maintain them I hwar mention of machinist tools that don’t seem to be as available as their cousin woodworking tools. i.e scrapers. Basically where do I find the machinist tools I want for maintaining/tuning hand planes and can anyone reccommend literature for getting into machining for woodworkers needs?
A good micrometer or vernier caliper will suffice for measuring exact thicknesses, widths, depths and for comparison of similar objects
A combination square (12") with 90 and 45 degree head. for checking miters and layout markings. An additional head for the square is a centering head To accurately mark centers on round and square work (such as wood turning) Starrett make's great machinist's tools (USA)
The companion piece for the tool is called angle dividing head (or, compass) for very accurately marking any angle and or to verify an unknown angle.
Check eBay or used tool auctions I've been using mine for over 55 years and plan to use it for many more
A good mill file (or two) will be good to file away nicks and scratches countersinks and counterbores, drills and taps are handy too. Steinmetz.
Edited 7/24/2006 12:01 am ET by Steinmetz
Hi Archibald,
Unless you simply want to go the extra mile, scraping and draw filing is overkill in the preparation to use a vintage plane. That said, check out Paul "BugBear" Womack's page for this:
http://www.geocities.com/plybench/flatten.html
Beyond the sole, just files would be needed if the mating surfaces of the frog and body need tuned.
New planes from the likes of LN & LV are as flat as you'll be able to scrape in all likelihood.
A light cleaning, a good sharpening of the blade, ensuring the cap iron fits the blade properly, frog fits squarely and is securely tightened down. For those things, some sort of sharpening medium, screwdrivers, sandpaper is about all that's needed.
Take care, Mike
Arch, the thin end of the wedge is well into position....There is no end to useful shiney things to get you into machining, so I just want to tell you one thing-forget about verniers and micrometers-these are now history. For measuring with ease, speed and accuracy every time we now have The Digital Caliper, which just can't be beat, and of the three common sizes I recomend the shortest which is the four inch.It also make a good depth gauge when fitted with a suitable base, as in the picture.That one is self made but they can be bought ready made.
