The Easter project failed!
Well, let’s say a big little unhandled plane that weighs 3.5lbs is not a design sucess. Too heavy to safely handle, and not confortable enough ‘in the hand’.
So under the knife it went. Chopped off some rosewood (sob), ploughed-in a 5mm groove, shaped a brass tang, rivetted-on some rosewood scales, and the Mack Truck has been transformed to a … what?
You decide. BTW, it produces lovely shavings, is fun to use, and can be sight-adjusted (without resorting to a hammer) in seconds. The bevel up HNT Gordon iron has a mirror finish, and takes a very keen edge.
Malcolm
Malcolm,
Don't know that I would quite classify the previous version as a "failure".... I thought it was quite a nice looking plane with comfortable-looking contours.
Anyway, a very interesting alteration to your design. The tote looks somewhat like a scorpion's tail, so perhaps you could call this model "the Scorpion"...
Regardless, it has a very sporty look to it. And, most importantly, it sounds like it works the way you want it to....
Cheers!
James
Considering the investment in these tools, James, if they're not the automatic first choice when you reach for a plane, then they fail, in my view! The Mack Truck version looked OK, and did the job well, but was a bit heavy for the grip ... a bit too 'hard work' to pick up.
With a tote and a drop front, it's fun to use, and will be a tool of choice in my shop.
Malcolm
http://www.macpherson.co.nz
Edited 5/1/2006 5:07 pm ET by Malcolm
Hi Malcom
I like the tote. It looks very functional, very business like. What I want to know is how you hold the plane - where do you place your front hand?
First, this was designed as a single-handed plane, Derek. One could argue that a front grip is unnecessary.
However, I like a 2-handed grip, even with my little Bristol Design thumb plane. So ... left hand naturally sits on top of the sculpted lever cap screw, with the thumb hooked behind, and the fingers resting on the short drop nose and guiding the cut. It is surprisingly comfortable.
The next version will be Deco-inspired, and I'm noodling with a front bun that is Deco-ish. The barrel-shaped handle used on my concept plane is one solution, and I'm also wondering about a horn that reflects the shape of the rear tote. Might look a bit like an angry Rhino, however! Perhaps I'm avoiding the obvious - a big balloon knob!
Malcolm
I think you got it right with the photo labels. Looks alot like a cat to me. Tail in the air. Aloof.
Any way you can get the shavings to exit behind the tote?
Andy
"It seemed like a good idea at the time"
> Any way you can get the shavings to exit behind the tote? <
Ha! Well done. Meercat, I thought. Shavings curling out of the front do look a bit like whiskers.
Malcolmhttp://www.macpherson.co.nz
