I’ve got a built in china hutch made from birch veneer plywood (door fronts and shelves) with poplar trim and poplar face frames. Its raw wood right now, and I want to stain it in Mahogany, to match my other dining room furniture. Any advice on the steps because of the mixture of woods? i.e. using a sealer or not before staining? what type stain (standard or gel)? using stained danish oil vs. stain and varnish? using varnish or polyurethane after staining? what to do, and what not to do? I know poplar is softer and more porous than birch, and want to ensure my end result is a piece of furniture consistent in color.
Thank you. Dan.
http://www.amazon.com/exec/obidos/ASIN/1561582883/qid=1039361929/sr=2-3/ref=sr_2_3/103-4644518-5233424
Great Wood Finishes: A Step-By-Step Guide to Consistent and Beautiful Results
by Jeff Jewitt
or
Understanding Wood Finishing: How to Select and Apply the Right Finish
by Bob Flexner
"I know poplar is softer and more porous than birch, and want to ensure my end result is a piece of furniture consistent in color. "
Realistically, its a little late for this concern, since the solid stock and the veneer don't match. Life would have been easier . . . based on your perceived experience level, believe you will be happiest with gel stains at the moment. The above books would also give you a wealth of other ideas and options, some of which would be time intensive, but have their places. In the event that you use shellac, have dyes, and access to spray equipment, there's another alternative as well. I'll go rummage around for it.
http://forums.taunton.com/tp-knots/messages?msg=9093.11
I was gratified to be able to answer promptly, and I did. I said I didn't know. - Mark Twain
Dan,
No expert here but I was re-reading the article on French polishing from the April 2002 issue last night and there is some stuff in there for you to condsider. He had different mahoganys to deal with. Sanded to 320, Hit with BLO and let gry for 5-7 days, then applied Blonde shellac. The next question is surface texture and matching the existing furniture..is that a concern for you? There are several alternatives for that issue.
You might want to take a look at that article. good luck T
