All,
I’m trying to decide the best way to make an oval 9x11x1.5″ picture frame for my wife. I’ve got a piece of Wenge that is rift sawn, oak that is quarter sawn and, my third alternative, is glue up two flat sawn pieces of 3/4 poplar. The rim of the oval will be about an inch thick. Any thoughts on the best option?
Hi BG ,
Do you plan to cut the oval shape from the stock as one piece ?
Maybe it is small enough that one piece could be fine .
Most ovals are made with a 4 section frame , the joints being centered top , bottom and each side .
I would use the more stable hardwood , the Poplar may not be worthy imo .
dusty
oldusty,
Yes, I was planing a one piece frame. I'm not sure how I'd orient the grain or the joinery on a four piece frame (another thing yet to learn). My main concern was weak points with grain orientation, am I correct in assuming that flat sawn would be stronger than qtr.or rift sawn in this application?
I could glue up a couple of pieces of 3/4x12 wide flat sawn oak..or I could resaw that oak into a four part lamination and glue cross wise?
BG,
If you intersected the vertical center with the horizontal each section a 1/4 oval and on larger frames may be seamed up several boards to make each section . The joints are 90° , in theory .If you draw a little square with the point up in the center of the oval the grain orientation follows the sides of the square.The grain runs in a straight line from each section to the next.
I would use Rift, it would be more stable a board in general as opposed to flat .
There wont be much torque on this frame .
you can do it ! dusty
