I have placed a copy of Sean (Sampson)’s “Making Frame and Panel Doors” on my website. The link to it is here.
Sean writes beautifully. I had minimal editing to do. His craftsmanship is just superb. There is much to learn from his presentation.
This is also an invitation to others who would like to publish a tutorial such as this. I have been revamping my website a little, offering a chapter dedicated to “Building Furniture – Techniques and Tutorials”.
Thanks for taking the time do do this. It is a great article and worth the effort. Bogart
Happy 2009
Thanks you very much, Derek.
I'm honored that you've given my posts a place on your wonderful site.
Happy New Year!
Samson - A comment about making raised, fielded panels by hand. If you've the opportunity, pick up a panel raiser at an MWTCA meet. These look a bit like big crown molders (woodies, of course), but have a skew blade and a nicker. These planes will allow you to make a raised panel in a big hurry (or with fewer strokes, tools, and set-ups, if you're not in too much of hurry). An alternative is a Badger plane, but for these to work effectively to make the raised panel, you have to cut grooves for the field edge across the panel's face. A panel raiser dispenses with that step, and does everything at once.
Some panel raisers actually make a panel with a beveled edge and a tongue on all four sides, so in some ways the final result resembles a modern, router-bit panel. I usually find it unnecessary to cut a tongue to fit the grooves in the stiles/rails - on most lod furniture I've examined, the sloped edge of the field is simply fit into the surrounding grooves.
You mean like this?
Yeah, I have one. Maybe I'm not using is right, but I can't get it to make different size bevels. ;-)
I'm not a fan of no tongue - i.e. just having the slope go into the groove. Too much risk of rattles and and stresses for my taste.
Yes, but of course what you have is a fixed panel raiser. Most of them that I've seen (and have) have adjustable fences on the bottom, so one can usually adjust the bevel width from about 1/2" minimum to about 3" maximum. Some of these do have the tongue-cutting provision like the panel raiser that you have, though they're not as common.
Just my opinion, but I think the risk of rattle is higher with a tongue. The reason is that the tongue cannot extend to the bottom of the groove on both sides, else humidity changes would split the panel or the door frame. When the tongue shrinks from dryness, it will allow the panel to vibrate fore/aft in the groove and rattle with each closing and/or opening.
I'll admit that the bevel in the groove would seem to run counter to the "space for movement" idea, but so far I haven't had any panels split or the frames come apart. I think the reason might be that the part of the panel contacting the groove is quite small, and is weak enough to give when the panel expands.
One nice thing about the bevel-in-the-groove method, though, is the top and bottom of the panel are wedged by the bevel bearing against the front of the bevel and the back of the panel in the rail's grooves. Since the length of the panel doesn't change, there's no possibility of rattle, and since it's a wedge arrangement, it's not necessary to carefully fit the width of the tongue on the panel to the width of the groove.
All of this suggests that the hybrid might be the best of all possible worlds - a bevel without a tongue on the top and bottom of the panel, and a tongue on the sides to allow for a loose fit and expansion/contraction.
Intersting thoughts, observations, and all around good information. Thanks.
THe other thing that caused me to shy away from bevels alone are that it would seem to require the woodworker to hit a perfect single point is sizing - that point where the bevel meets the groove. That point must be perfect all the way around the door. I tend to try to come up with designs that leave me some wiggle room. Maybe if I was a better wood worker ...
"THe other thing that caused me to shy away from bevels alone are that it would seem to require the woodworker to hit a perfect single point is sizing - that point where the bevel meets the groove."
Actually, this is pretty easy. You don't have to perfectly hit the bevels on the sides, just the ends. Since the length of the board will not change dimension, so long as it's wedged into the grooves in the rails, all that matters on the sides is that the bevel's at a shallow enough angle and the groove's wide enough to get 1/4" or so "hidden" behind the front wood of the groove.
Also, I, like you, use hand tools because it allows "sneaking up" to a good fit between mortise and tenons, dovetails, bridle joints, etc... In the case of panels, I cut the panel to be about 1/2" over the dimensions of the inside of the rails and stiles all around, so that 1/4" will be captured in the grooves. Then I just plane with the panel raiser until at least 1/4" will fit into the groove in the stiles, and as close as I can get to 1/4" in the grooves in the rails.
When you assemble the door, most common cabinet woods have a little bit of give, so I've found that it's not necessary to get things precisely, exactly on target. If I were doing this out of a hard, dense tropical wood like rosewood or ebony, I think I'd be a lot more concerned.
Other problems I've had with the panel raiser - in hardwoods it can be problematic across grain. And as I lack a pair, it's also a problem on one side of the long grain (you're going against it). Especially a problem for anything with curl.
Love it for pine and poplar though.
Ooooh Sean, that panel raiser is beautifulll! A Robins? I would loooovvvve one!
My short cut (or quicker method) is to cut a rabbet on the rear of the panel ..
Then, having marked out carefully, cut the field and the front slope to the edge ...
.. checking the final dimensions with a scrap of the groove ...
Result ....
Edited 1/13/2009 8:44 pm ET by derekcohen
I'll have to give it a try. Thanks, D.
Derek, Fine example of Knots at it's best. Thanks for the link.
Tom.
De
Sean, GREAT article and VERY MUCH appreciated. Thank you most sincerly. Patrick
Derek, very considerate of you and also very much appreciated. Patrick
Well done,Derek.
I can add nothing to what the others have already said. They are spot on.
Robin
