Hello,
working on a kitchen table build and have decided I’d like to try and use buttons to secure it. However, I was trying to think of ways to efficiently make a lot of them and had an idea; why not glue a thinner but longer piece to a thicker and shorter piece to form the tongue that sticks out on the buttons? My thinking was that you could still keep the same grain direction the glue bond would be plenty strong
That'll work, but I don't see a savings in time or effort over cutting them out of solid stock. Go for it.
“[Deleted]”
Sure it will work. But it's a ton of time, effort, and mess.
Make a series of dados on a board, rip it in 3/4" inch strips, crosscut the buttons. I could have made a few dozen in the time it took to write this.
Good practice sawing to a line as well if that is of interest.
If you have a nice wide (flat) board, dados go quickly.
Thanks for the input everyone, my problem has been the lack of wide stock to go about button making the usual way; figured this might be a good way to do it with thin scraps I have leftover
Sometime you can let it be about the journey, after all you'll be going slower than you might go for what... probably under an hour?
A contractor pal of mine would shrug and say... "Sure, whatever's hardest!".
