For a skill building (and ultimately utilitarian) purpose, I am building my first set of winding sticks.
For those with experience here, how should I proceed?
So far, I started with with 6/4 x 3″ x 30″ quarter sawn white oak which as of last night, is as flat and square as I know how to make it.
I am intend to clamp the two boards together and do a final fine shave with my trusty #7 bailey just match up the edges.
I was also considering adding 3 or 4 dowel pins along there length to for storage protection and to resist any movement when they are stored. Also will add corner markings for sighting.
I’m sure I’ve missed several key points. Any advice is appreciated.
Family Man
Those aren't sticks, they're timbers! My set are mahogany with maple on one edge for contrast. They are much lighter made than yours. You certainly don't need to go to 6/4 to get stability in white oak. Are you working outdoors where wind might be a factor?
I could not help but chuckle here, yup I agree his winding sicks are indeed timbers and gee whiz is his shop in a tonado zone :-)
I have rather small set of winding sticks I made whcih are stable and as flat and square as I could get them. They are only 16 " long about 5/8 ths wide etc. they work fine n dandy
Mine are only 3/8"x1 1/4, one set 18" long, second set 36", walnut and maple. I also bevel the edge to make the line thinner. I check them once a year or so for straightness.
You might check out FWW several months back; there was an article on making winding sticks near the back of the issue, but sorry, I don't remember the issue.
It is issue 177 from June 2005 page 91.All the bestStuart
Why not just use a couple of peices of aluminum angle iron?
Will steel angle work or must it be aluminum? Where did you find aluminum angle iron, never herd of it? I thought it was either iron or aluminum angle. Sounds like something cool.DJK
:DGood catch.Will we still call it a plane iron when it's made of plastic?
You should see how wrinkle free my wife gets my clothes when she aluminums them
At least your wife uses aluminum. After I iron my own, I must apply WD40 or Bioshield as a rust preventative.DJK
Steel or aluminum, either ok.
Sample at the straight edge link, (8 & 12")
Edited 12/4/2005 6:05 pm ET by Routerman
Do you recommend getting two 8” or one of each (8” & 12”) or does it matter?
Does not matter, test if in doubt.
8" of anything is a lot to sight broad-ways.
I use any two straight chunks of wood that happen to be near me when I need to check winding. They don't have to be the same dimensions at all. Don't belabor the point.
On my set I sealed them with a white pigminted shellac primer (Zinzer BIN). This added protection from humidity swings. I then masked off graduated horizontal lines which I painted black. I based mine on the metric system because .oo1 is a lot easier than 1/128". I am working on a set made from granite and I will add a lazer sighting system to speed set up time. However on the Discovery chanel I saw this new GPS type system that brain surgeons use to increase accuracy in their operations. It is accurate to a micrometer, and should be easy to add to a winding stick. I hope to find one of these surgical instrument positioning devices on Ebay, but they are hard to come buy so I'll likely have to make my own.
Heh heh, Just kidding. Like someone else said I use what ever is laying around, preferably freshly ripped MDF.
"I am working on a set made from granite and I will add a lazer sighting system to speed set up time."
Hey, does Rob Lee know about that? ;-)
Scrit
Who?
As in Lee Valley, Veritas, etc. ;-)
Come on... Theirs will be made from machined billet brass with cocobolo infill. Lazer engraved reference marks and and a knurled brass thumb screw will allow for percision adjustment. Not to mention the wooden protective case.
And there was me hoping for a set in malleable cast-iron (nickel plated, of course)with a bevel-up option..... ;-)
Family Man
In reality my current pair are about 1-1/2 inches x 5/8 inches section and about 16 and 30 inches long respectively. Made them from beech offcuts and just painted the outer corners white on one of the pair and black on the other one. When not in use they are kept together with rubber bands (thank you Mr. Post Man) and stuffed inside a sealed plastic bag. The top edges are bevelled.
Scrit
The problem with cast iron is that there are so few state side foundries that will do that kind of work economicly. And you can't expect them to out source that to Asia.
In that case we'll need to ask Rob to move to titanium ;-)
Oh yea now your talkin'. Nothing says USA like machines Ti. Pluss corosion and rust proof.
Is he planning on enforcing a patent to prevent anyone from posting the method?
Thanks all for the feedback. I have to say I got a good chuckle at the timber comment on size. As with most things, the beginner's finesse is nonexistent. I
did suspect these to be very large, but its what scraps I had on hand and I figured I needed the practice reducing them if needed.
The more I practice, the more I appreciate all of the help from you.
Family Man
I'm glad you saw the humor in it. We all learned something about a simple thing from this string of posts. Like Mr. Rogers says: Can you spell c-o-o-p-e-r-a-t-i-o-n?
