I have an opportunity to purchase some 4/4 “Malasian” Mahogany for what seems to be a reasonable price. It was origionally purchased by a boat builder who is no longer able to complete the project.
Since I don’t have experience purchasing wood, what do I look for in the wood to determine it’s type and grade?
I ask because the price locally varies between $5 and $15 CAD / bf depending on country of origin. From what I’ve looked up on the net mahogany isn’t even grown in malasia.
Thanks…
what do I look for in the wood to determine it's type and grade..
mahogany isn't even grown in malasia.. They have everything that grows!
If he is REALLY a Boat builder.. They use the best for the money they had at the time for the project.. Well, usually...
It will probably be either Sapele or Meranti as those are the Malaysian mahogany lookalikes.
You'll have an opportunity to inspect before you buy?
I agree with Will, boatbuilders normally use the best grade timbers.
IanDG
Ian, Sapele is a wood native to the west coast of Africa of the Meliaceae family, whereas Meranti is one of the Shorea genus out of eastern Asia (Dipterocarpaceae family.)
Of the seventy or so species that make up the Shorea's I can think of commercial names including about fifteen different meranti's, a lauan or two, and a seraya. Some are very soft, light, non-durable and woolly, and some are heavy, dense, quite durable and hard.
Someone put up a picture of the wood they'd got. It looked suspiciously like what I'd call Philippine lauan, one of the meranti's. Soft, wooly, interlocked grain (and if it has those characteristics) close inspection might reveal the quite common thunder shakes running perpendicular to the board length. Slainte.RJFurniture
Richard,I agree. It looks like luan.This is a very soft "hardwood." quite "cheap" looking in all respects. It looks like mahogany from a distance but has none of that wood's density or structural strength. It's grain doesn't fill well and finishes tend to look "tacky" no matter how much care is used in their application, from oil finishes to thick-film varnish or lacquer.It's commonly found as very thin skins on low-price hollow core doors that big box stores specialize in.Rich
As a boat techno freak I'm willing to bet he intended to buy Honduras mahogany and was fooled into the "Malasian" version They really aren't alike at all and would be a lot differant. upon seeing it he ordered the real Mahogany.
There are a lot of cheap look-a-likes out there, please don't be fooled..
What is the difference and how do I tell?What would be a good price per bf of the malasian type?
Edited 6/27/2005 10:21 pm ET by AEsarte
Ok, here are two samples taken from perpendicular planes of the same wood. What species is this in your opinions?(It seems fairly soft when working with hand tools, much softer than walnut...)Andy
Second sample, from the plane perpendicular to the boards surface...The boards are a light brown with a pinkish color inside.Andy
If the sawdust has a sweet smell then it's sapele.
IanDG
Hi Ae,
Your second pic confirms that it is Meranti, without a doubt.It is most definitely not Sapele, which is from Africa, and has a pleasant smell similar to cedar, and is stripey when quarter sawn.Meranti is variable, has a mild smell sortof peppery, is softish and there are several types, broadly divided into white, brown and red. The good thing about Meranti is that when grain filled and stained it can be made to look like a million dollars.
It looks like meranti, one of the many Phillipine/Indonesian "mahogany" types. It is soft and is often used in lumber core, It is NOT mahogany as a species just resembles it....sort of. aloha, mike
Has anyone used meranti in furniture construction? It doesn't seem to be much harder than cedar. Does it produce nice stuff or is it more of a utilitarian wood?
Andy
Andi,
I have worked with both Sapele and Meranti and don't consider either a high grade cabinet wood. Sapele is quite popular here in the US, but I think it's more a name/import thing. The times I have laid my hands on bargains here, they all ended up as drawer sides, or shelves.
Overseas, both are often used for base boards and finished in their natural color. (Overseas "base board" = "skirting")
There may be different opinions, but be sure, neither are near the same class as Mahogany.
That stuff is also used for cheap commercial doors (usually veneer) and frames, for plywood , cheap panneling , DIY bits of wood,and other cheap commercial applications.
Philip
