I’m making a kitchen table for my daughter and have stained it with MinWax stain/sealer (Colonial Maple).
Can I use Maloof’s poly/oil mix over the stain? Or has the stain/sealer negated the absorption of the oils in the Maloof mix?
And, if I can use it.. is the poly/oil mix suitable for a kitchen table or should I opt for pure poly?
Thanks in advance,
Bill
bill, you could use it over the stain if the stain had cured, but you really need something harder for a table top. Bill
I have some MinWax fast drying poly. Will that be hard enough?
maybe someone ought to tell Maloof
Do you think the Maloof oil/poly is hard enough for a tabletop? I used it on a walnut computer table and it seems to be holding up.. but there is never anything wet or hot put on it.
I would recommend something more substantial. I have a kitchen table finished with Gloss poly (it's harder than satin) and a dining table finished with Boiled Linseed Oil and a couple coats of The Maloof mix. There is no comparison in durability, the poly wins hands down. The problem is the visible film poly leaves. If you can live with that poly is the way to go. Thin coats. I use Minwax spray. Use a cloth lightly sprayed with the finish to wipe all the dust off.
There are more old drunkards than old doctors. Ben Franklin
Thank you, sir. I'm going with poly. Looking through an old FWW article I read that applying the first two coats with gloss poly, followed by satin, gives you that satin look without the cloudy film. I'll try it that way and see what happens.
A lot of pro's recommend using gloss for all coats then buffing with 0000 steel wool down to whatever sheen you want. I've done this and it works.There are more old drunkards than old doctors. Ben Franklin
You can use spar varnish, too. That's what has been used for years on wooden boats. Gloss finishes are generally harder than the others, decreasing in hardness as they become less glossy. Using 0000 steel wool or fine ScotchBrite works well for removing the gloss. If you have ScotchBrite pads that seem to be just about dead, they'll be just about right for this, as long as the finish has cured completely.
On a bed I built I used a 3 part finish using mineral spirits, Turpentine, and Spar varnish as Garrett Hack uses. Man, it stinks like crazy. Spar is softer and more flexible than poly so I'm not sure why anyone would use it on a table. Those attributes make it great for boat use.There are more old drunkards than old doctors. Ben Franklin
Just curious, why are ther two different thinners in that finish? Does one of them affect the hardness or is it more for the drying characteristics?
I wondered that myself. Both mineral spirits and turpentine are thinners. Both completely evaporate leaving no trace of themselves. You could use either one individually with exactly the same results.Howie.........
....because I was tired when I wrote the response. It should read, Turp, Boiled Linseed Oil, and Spar Varnish. Sorry for the confusion. Normally I use Mineral Spirits, BLO, and Gloss Poly.There are more old drunkards than old doctors. Ben Franklin
That's OK, I was tired when I asked the question. Now it makes sense. Equal parts or more thinner than BLO?I cut this piece four times and it's still too short.
I like to use equal parts BLO and poly with a little less on the mineral spirits. Equal parts of all three feels really thin to me. To each his own I guess. Wet sanding, with the 3 part, during the second or third coat really smoothes it out. On any kind of table top use at least 4 or 5 coats. Even that may not be enough for thorough protection.There are more old drunkards than old doctors. Ben Franklin
I have been using Minwax fast drying poly thinned (for spraying only) with Naptha. If I brush it on, I use foam brushes. If I need to fill open grain, like oak, I thin it, brush or spray it on and after it sits a few minutes, I go over it with a green ScotchBrite pad. After a few coats, it has a nice, even coat with a satin look. I use either semi-gloss or gloss, so the finish is harder.I cut this piece four times and it's still too short.
You can also use a non-poly varnish for a warmer look--in my opinion. I wipe on satin varnish thinned 50/50 being VERY careful to keep the finish swirled to insure the flatting agents are kept in suspension.Gretchen
