Can anyone tell my a way to remove the bark on a seasoned maple burl?
Most of it poped off with some force from my knife, but I want to finish it minus the bark
I've done this. But I am hoping that someone has a great tip.
After it is completely dry, it is easier to remove. I ended up pulling off the big pieces, the carefully picking off everything else. Some of it was really stubborn!
Hal
http://www.rivercitywoodworks.com
Hal J:
Love your web site, you do some stunning work.
Thank you for the responce I am trying to pick off the bark one little part at a time, tried a wire brush it didn't do much but i will over come one way or another.
We have another post you might be able to help with as well. Need to make some ebonized maple that I can cut smaller after ebonizing they will become pin stripping in a segmented bowl ( the reason they will be recut) .JigSawJohn
One of those little picks used to get the meat out of a Crab or pecan works pretty well too. Just shapen it a bit first.
Sorry to hear about your lung. Bummer, man, that really sucks! I hope you feel okay now.
Hal
Why don't you use Wenge or black Ebony?
Hal
Have been using ebony but I am finding that softer woods next to the ebony section gives some problum with density differance when sanding, so I thought I'd try dieing maple since it is closer to the other woods.
I do appreciate all of the imput I am getting gives me room for thought.JigSawJohn
would a draw knife help? It would seem as though it would be easy to control that tool.
...The unspoken word is capital. We can invest it or we can squander it. -Mark Twain...
John,
Make sure you wear a good mask while you are doing this. As I recall from my reading, there can be some nasty stuff living under that bark that can make you more than a little bit sick if you inhale it, including molds and fungus.
Thank you very much I have lung problums as it is. It seems to have come from maple spore desies, (turning spalted maple) I had part of a lung removed a few years back.JigSawJohn
