I am a novice (but with good equipment) hobby woodworker. We are just completing an addition on our house which includes a new, fairly contemporary kitchen. The cabinets are made of sycamore with plain fronts, which some metallic looking cabinets (looks a bit like brushed aluminum) mixed in to break it up, and the countertops are Absolute Black granite (which actually has a lot of small gray flecks in it). Our old kitchen table and chairs won’t match the new setting at all. I’m thinking seriously about building a pretty simple maple table base (consistent with the contemporary setting) (the sycamore has similar tones to maple) and having the granite place make a top to match the counters. Here are my preliminary thoughts:
Start with 3″x3″ maple for the legs, taper them to 1.5″-2″ at the bottoms.
Use 1.5″x5″ maple for the stretchers with a very simple detail along the bottom edge (rounding over the bottom edge with a thin, shallow kerf above it), joined to the legs using motise and tenon joinery.
The table would be sized to seat 6 people – 2 on each side and one at each end. I’m thinking of a top about 40″ wide and probably 6 feet long. I’ll work with the granite guys to figure out the best way to attach the granite top to the base.
I have a Mini Max CU 300 combination machine to be able to plane, joint, cut the stock, plus a morising attachment for the leg mortises. Oneida Super Dust Gorilla collector. This is in my basement shop in my house.
I’m interested in getting input/advice/guidance as well as being pointed to any resources people recommend for table joinery. I searched the FWW archives on this site and turned up a couple of useful articles, but I know this is the best resource for advice. Thanks in advance for the help!
Brian
That is completely feasible. You might consider a plywood subtop. It would fill in the space between the four rails. There would be two benefits: it would act a great big gusset for the leg joinery and hold the rails straight; and it would help support the stone slab.
I'll second the suggestion for a subtop. I built a maple conference table with an 8' granite top, and used a 3/4" plywood subtop. The granite will to stay put with gravity. You may need to get it off some day to move it, so I'd hesitate to fasten it....
Edited 10/20/2006 2:47 pm ET by Knotscott
I'm curious as to how much the granite table top would weigh?
I would like to do something similar for end tables. Thanks,
Rod
They're all different depending on the granite itself and the dimensions. The 3' x 8' top we used was ~350#. 1" material will be roughly 70 Kgs/sq meter.http://www.simetric.co.uk/si_materials.htm
