We have an English dining room table, turn-of-the century walnut burl veneer with peripheral ‘oysters’ of lignum vitae or yew. Some minor irregular marks have recently appeared on one part of the table – under a lupe the marks look like crusty flat ‘blisters’ in the finish. They are not large, maybe 1/16″ – 3/32″ across. The table has not been used in about 8 weeks or so.
I’m assuming the table has a French polish or shellac-based finish – in fact the ‘blisters’ (heat damage? alcohol?) look a bit like crusty little shellac flakes under the lupe. While we most likely will hire a professional to look at these, does an approach of re-amalgamating these small finish defects with denatured alcohol sound like it would make sense? It looks as if these small areas would ‘melt’ into the surrounding finish if that was done.
Or does this add more risk than it is worth?
Thanks for your input – (I would post a photo but the marks are very very small)
Hi Jeff.... If you re-post this question in the 'finishing' section, I'm sure you will get better results
SawdustSteve
Jeff,
Your question of risk vs.worth is well worth considering. From your description it doesn't sound like much of a problem. Without seeing it, as a professional, I would advise you to leave it alone.You've heard the phrase "first do no harm" I assume. If you start to fix these very minor flaws I promise you will make them bigger. Then you will have a real problem.
If that finish is original to the table and it is turn of the century, leave it alone.Just think of the marks you'll have after a hundred years.
