I’m building a fireplace suround that’s essentially frames and raised panels. Some of the panels will be faily large, so I was worrying about glued up panels splitting from the heat. Should I consider making the panels of MDF? The panel will be painted; can I raise panels of MDF and get it smooth enough to paint without it looking like well…… MDF?
Yes.
When painting MDF, I've had trouble using waterborne paint directly on the MDF. It has caused bad grain-raising. I now seal with shellac (Zinsser) first.
In late Victorian, early Edwardian times, fireplaces were commonly made of wood and still survive in good condition. Mine I made from iroko and there are no problems. I think that provided your wood is dry and stable at the time of use then you will be ok. I used reclaimed quarter sawn stock.
Quickstep
I've used MDF on raised panels for fireplace mantles and have had very good luck with it.
Seal the MDF profile with either a watered down yellow or white glue or a good oil base paint and you'll be fine.
Doug
