I would like to build the crosscut sled by Chance Coalter in the latest Tools & Shops issue. He recommends using 1/2″ phenolic plywood. I have not been able to find this product in the Houston area (Woodcraft only carries 3/4″). I found a source for MDO, which also has phenolic resin in its coating. Is MDO similar to (or same as) the properties of phenolic plywood (e.g. strength, durability, flatness, slipperiness, sealing the interior against changes in humidity)?
Phenolic plywood is extremely slick, and MDO is not. I'm not sure you can make MDO slippery.
Phenolic is also a lot denser and thus heavier than MDO.
If I couldn't find Phenolic, I'd use Baltic birch.
Thanks for the reply
I use MDO for a lot of my jigs, including my crosscut sled. I agree it's not as slippery as Phenolic ply and not as dense, but a light sanding at 220 and a coat or two of paste wax makes it plenty slippery. Or you can add a strip or two of UHMW tape. MDO is plenty stiff enough for a crosscut sled, is nice and flat (if it's been stored properly by dealer) and the lower density translates to lighter which is actually helpful for a crosscut sled. And of course, these days, MDO is a lot cheaper than BB, if you can even find it. Bottom line, IMO Phenolic ply, MDO, and BB can all make a good, stable sled.
“[Deleted]”
Tried to post this a big ago but for some reason it did not take. I actually quite like MDO for this kind of thing. As carbide_tipped notes, you can make the underside slippery, and the top side has a nice texture to it--not sticky like sandpaper, but a little bit of friction helps keep your workpiece in place.
I find the offcuts to be super handy around the shop since they are so flat and uniform--wonderful for fences and such. Uniform on the faces, that is. The edges may contain some voids--it's like good-quality construction-type plywood on the interior. Nothing major, in my experience, just not perfect.
