I would like to turn a rolling pin but have the handles move separately from the rest–like have the handles screwed onto perhaps a threaded rod that goes through the wooden pin. Does anyone know of a mechanism available that would make this easy to do? Or plans to assemble your own? Thanks for any help.
I know that the high end kitchen shops sell ballbearing rolling pins, but I never quite saw the point. I find that a rolling pin with the handles turned solid as part of the stock works just dandy. Or just through bore the rolling pin and the handles and glue the handles to a dowel.
You turning a bois d'arc rolling pin?
BJ
Yes, I have some osage I might use, also other woods. I think a dowel in the middle might not give a smooth enough action--but thanks for the thought.
HeyOsage:
Rolling pins are one of my favorite Christmas gift items. Mine are usually made from billets of Tenessee red cedar. I turn the handles separate and thru bore each for a pin. The pin is a maple turning with a knob on the end. I bore each end of the roller 3"deep to accept the pin. A little epoxy in the hole holds the whole shebang together. I finish the handles in the lathe with several coats of polyurethane,no finish on the roll itself.
Some have actually been used to roll dough.
I salvaged some osage from a downed tree some years ago. This material makes fine billy clubs for policemen. ¬¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬¬
The rolling pins we used in my shop when I had a bakery had a shaft through the center with a bearing pressed into the wood or later aluminum pin. The handles locked onto the shafts threaded inds be means of a two-piece handle.
I now use them as out feed rollers. Being of fairly large diameter with bearings they roll smoothly and work great!
George
