i picked up two cherry logs yesterday from a friend and i am taking them to the band saw mill today. just wondering what the best way to get them milled is . i have never worked with cherry before. quarter sawn, 2″ slabs all the way thru, 1″ slabs, or any other sugestions? the logs are about 16″ to 18 ” d at the butt and there is 10′ log and an 8′. any input would be great thanks.angus
Just my thoughts so I could be wrong...
If the place is good you should be able to ask the operator/boss/sombody to look at your log and ask what would they recomment for the best grade of cuts they can get out of it..
angus
I always mill my cherry "mill run", which is flitched. That way you'll get a little of both. I use cherry more than any other species, and love it flat sawn, but there are times when having some Qsawn is great, like rails and stiles for cabinet doors. Can't beat straight grained stock for that!
J Please send address so I can break into your wood storage!
I'll provide a truck. Even split?Leon Jester
I would like to attach a photo of a piece of cherry I had milled. How do I do that? I pressed the "Attach Files" button below and nothing happens. Oh where have I gone wrong...
I agree with JHeath - just cut it though and through.
I like 8/4 for all my wood - I use smaller pieces of thick stuff for legs and resaw bigger stuff for bookmatched pairs.
If the sawyer is good, the heart can be boxed in the center slice.
For that size log, for your own personal use, I agree with the others, of just sawing through and through.
If you are going to be drying it yourself, I would suggest that you paint the ends ASAP. Be sure to de-bark it. It will attract powder post beetles more if the bark is left on.
It is also recommended to start your stack up on some blocks rather than right off of the slab / ground to get better air circulation into the bottom of the stack.
rootburl
Good advice about getting the logs off the ground as high as possible. My pic doesn't show it, but my stack is on a 4x4 base.
I left the bark on this stack, and have not had any problems with bugs. I sprayed the heck out of it with Malathion 50 before milling it. It has not affected the wood, and so far, no bugs in any of the boards.
thanks guys I appreciate the advice.
Angus;
I have had several logs sawn into lumber from people giving me the logs and I can tell you that there is no one right way to do it. Personally, before I committed to how thick to cut the boards and quartersawing and whatever, I would take a few days or longer if necessary, to think about the projects that I were going to build before I cut any lumber.
If you are going to make say a matched dining room set for your wife, I would consider cutting the boards normanlly, ie. rift cut or flat cut, because quartersawing wastes a lot of wood and the boards are not as wide as normal, even thought they will be a lot more stable and look a lot pretier. However, this is the decision making process that YOU have to go throught. Also, as far as the thickness goes, I would not cut all of the boards the same thickness, because of all the different uses that you will have to make a project. For example, you might want to cut a couple of boards 2" thick for legs and drawer fronts that would be book-matched. Or, depending on the use, like a dining room table top or a buffet top, you might want to cut 2,3,or more boards a full 1-1/4" thick for the top or doors and drawers faces. Really, you are very fortunate to have the availability of a friend that gives away such pretty wood, so if I were you, I'd think a little while about the projects that I was going to build before I cut any boards.
Let me know how it comes out and, when it's all said and done, the only one that has to be satisfied is you and your wife, if you are married. If not, then it's strictly a personal taste thing.
If you are going to make say a matched dining room set for your wife, I would consider cutting the boards normanlly, ie. rift cut or flat cut, because quartersawing wastes a lot of wood and the boards are not as wide as normal, even thought they will be a lot more stable and look a lot pretier. However, I'd do it on some scrap wood and ASH HER FIRST if she like it! Ya NEVER know!
I'm not only new to this forum but almost as new to woodworking. I came upon a cherry log that a fellow was going to cut up into fire wood. I thought that would be an awful waist so I hired a guy with a portable mill to cut it into different thichness' of planks and now have it drying in my back yard. I hadn't known that cherry had so much grain to it. What a pretty wood. Now I just have to learn enough about wood working to make some things from it. It has a lot of grain which I didn't know cherry had. I was going to attach a picture of it but apparently I'm in a bad area for emails. It wouldn't attach. I travel a lot.
