Has anyone found the qt. size of Min-Wax wipe on poly @ or near the suggested price of $5.95 as stated in FWW Aug. 05?
Jshetfield,
No, I think I paid at least double that for a pint...last Sunday at HD in NH.
Make it yourself and save a lot of money. Get a gallon of poly and a gallon of mineral spirits -- total about $30 or less. MWOP at $9/quart makes it $36/gallon. I've used MS/Poly mix ratios from 3/1 to 1/3 depending on application.
Bill Arnold - Custom Woodcrafting
Mensa Member
Click Here if you're interested in a good, inexpensive website host.
I do the same except I use Naptha. Also mix from 3 parts poly, 1 part naptha to 3 parts poly, 3 part naptha -- depending on application. Mix as needed, not before.
A bad day woodworking is better than a good day working -- yes, I'm retired!
I use naphtha as well, especially with higher ratios of poly -- helps the drying process. If I'm on just an oil coat, I'll use either one.
Bill Arnold - Custom WoodcraftingMensa Member Click Here if you're interested in a good, inexpensive website host.
I think that was a typo!
I just paid 7.95 in the Denver area about 2 weeks ago.
