Are there any mini Max 16″ BS users out there who can tell me what the largest blade they’ve been able to tension adequately for resawing. I know it advertises 1.25″ blade as max width but was wondering if it could tension a carbide blade in that size. Thanks.
The blade that came with my MM 16 was 1 1/4" from the back of the blade to the widest part of it's hook.
With a new tension gage that I bought from Iturra I measured 32,000 psi. Everything tracked real good. I figured why not test.
The bigger blades I'll usually tension a bit lower. 20,000 t0 25,000 psi.
1/4" or less I crank up to 25,000 psi or more.
I use bi-metal blades. Lennox usually.
PS: I never detension my saw. I figure if the saw is too weak, I'll get a better one.
The proof is in the puddin'
Without stealing this thread - sorry. Is there a web site for minimax? I'm in the market for a BS and am hearing/reading nothing but good about Minimax.
Jim
I think there is a site for everything.
hehe
http://groups.yahoo.com/group/MiniMax-USA/The proof is in the puddin'
Thank You.
Jim
Try http://www.minimax-usa.com
Ted
i got a carbide blade with the mm - when i tensioned it up to about 25,000 found that it was too much - the wheels would not spin - i guess that the metal of the blade was just too thick - so i backed it down to 21,000 - no problems there. but i do set it to the higher set for the all steel blades.
i do detension after the day's work.
jerry
"I never detension my saw. I figure if the saw is too weak, I'll get a better one."
Aren't you asking to have trouble with the rubber tires on your bandsaw? I'd think that constant tension would flatten them.
My practice is to de-tension my bandsaw when done for the day. I do this because leaving the tension on with my 14" Jet bandsaw caused metal fatigue and I had to replace a part. I've since upgraded to a Laguna bandsaw and would suspect that it wouldn't suffer the same malady (metal fatigue).
John
I just got an email from MM saying they were about to raise their prices...something due to losses in the US dollar. Grumble *%&*^ mumble
Tom
