I am having a problem with a new Mini Max MM20 bandsaw that I am trying to setup. It appears that the lower blade guide is not correct. The lower guide looks identical to the upper guide. The lower guide does not move back far enough so that the teeth do not run between the guides. I am setting it up with a 3/4″ blade. The proper setup for wide blades is to run the teeth over the front edge of the wheel. Narrower blades are to be run in the center of the wheel. Does anyone have one of these saws to compare the upper & lower guides?
Chris, I also have a MM20. The solution to your problem is to remove the lower guide. Between the lower guide and the saw back is a large, thick black washer. Remove the washer, it serves no purpose, and you will gain enough clearence for your blades to run in the guides in the correct position.
Bear
Bear,
The washer behind the bracket on my saw is only 1/16". I need at least 3/16" just to be able to safely use the 3/4" blade. To be able to use the 1/4" blade that came with the saw, the guide needs to move back at least 1/2". That is setting the 1/4" blade in the center of the wheel as the manual states. I am attaching 2 pictures of the guides. Thanks
Go to the MiniMax discussion group at
http://finance.groups.yahoo.com/group/MiniMax-USA/
You'll get the definitive answer there, probably direct from Minimax USA
MalcolmNew Zealand | New Thinking
Malcolm,
I tried that. That group is moderated by Mini Max. They must approve all members & posts. It took several days for me to be approved as a member. I tried to post this question there early saturday. It must not have meet with there approval as it was never posted. Although there are several posts from people bashing Felder. Some were posted after I asked my question. I no longer see any value in that site & am no longer a member.
Shame you gave up on the MM user's group. I joined last fall and think it's a good group. The procedures at sign up are meant to keep out spammers. No censoring that I'm aware of; if you go back through their archives you'll several posts and threads that hold MM's feet to the fire including one rant that's particularly hard on the machine I own, the S14. If you go to the file section of the group, there's an online bandsaw manual (.pdf format) that might be of help. I seriously doubt your question was censored.
Edited 4/3/2005 10:22 am ET by jc
In your second pic of the lower guides, something looks weird with the vertical adjusting bar that the guide housing is bumping against. Can that vertical bar be repositioned (reversed?) in some fashion to allow the clearance you need. I have an mm16 but have not run into this issue.
Bill
I know my washer was thicker, but they change things alot. The wheels on the MM 20 are not crowned like smaller bandsaw, so it does not matter if the blade runs in the middle or more towards the front. The larger blades run with the teeth off the wheel,as you know, because they have more set and will chew up your tires. Try running the blade more toward the front and see if you can get enough ajustment on the guides.Bear
I got the problem taken care of. It is amazing what you can do with 2 hours, a hack saw & a file. The bottom guide now moves back as far as the upper.
The MM16/20 Manual has been a great help to me
