Often wondered if wiping the exposed faces of a joint with a damp sponge (pre-wet them to minimize absorption) would make sponging off of squeeze-out Titebond easier. Can leave water stain/raised grain, depending on the wood, but then so will sponging off squeeze-out. Tried this a couple times and cleanup of squeeze-out seemed much easier, but chickened out worrying that I might be missing good reason(s) not to pre-wet. Feedback/experience/… greatly appreciated. Thanks.
Don,
Everything I've read says nothing wet around the glue. Water can get into the joint and weaken the bond. Better to learn to avoid applying excess glue and obviate the squeeze out at its source.
Don
If I get squeeze-out, I wipe it with a damp cloth that has been wringed out. Then immediately wipe with a dry cloth. Any grain raise will be eliminated with sanding. If you let it dry, you're going to sand anyway. Most of the glue will be gone when you do and the sanding wil be much lighter.
If your joint is tight, I don't personally think that enough moisture will get in with a squeezed out wet cloth to affect the joint. Just dry it immediately. Could the moisture affect it in the long run?? Possible, I guess. I got some pieces I made 30 years ago that it hasn't affected yet. Could turn loose any day now, I suppose. Keep you posted. <G>
sarge..jt
Don , I only use a damp cloth on prefinished or furniture repairs to wipe off excess glue . Try removing the squeeze out with a sharp chisel . You can even let the glue semi dry before you remove it . I think the glue has some joint filling qualities as well . No matter which way you remove the squeeze out you will be sanding afterwards to clean up . good luck
To minimize sqeeze out stains i typically take a bunch of blue masking tape and tape around the joint itself as much as possible.
Then any glue that does seep out will be on the tape instead of you precious wood, and the tape comes off quickly and easily without leaving any marks.
Though i gotta admit sometimes on large pieces its a pain in the butt to put all that tape on :)
JD
