Are you really supposed to NOT wipe off the poly after appying, just let it sit?? I usually wipe it off a little bit but I need to build a finish fast today, can I just let it sit and it will even out and soak into the wood on it’s own? Thanks for any tips!!!!
Brush
Why not just brush on 2 full coats of poly regular strength for a base - give light sanding - then one light wipe on coat as final finish
SA
I hadn't thought of that with polyurethane
SA,
Brush then last coat wipe on.
I wouldn't hesitate to do that with shellac but not thought of doing it with poly.
Thanks SA you have enlightened me !
You don't let it sit, but you don't put on so much that you really "need" to wipe it off. I wipe it on as far as it goes--just keep spreading untlil it is all off of the rag. Then start again on another section. You can put on as many as 3 or even 4 coats in a day. It shouldn't dry between coats. It will not soak into the wood on its own, particularly after you have a coat on.
The suggestion to brush on, and then wipe is sort of asking for problems for me--the wipe on is really fool proof for not getting runs and stuff in the finish.
Poly
Roc -
Why couldn't you wipe on a poly finish just like a varnish finish ? Thin + apply -
Gretchen -
I say brush first because poster wants to build a finish -
SA
The poster wants to build a finish FAST. I can put on 6 or more coats of wipe on in two days that it will take one brushed coat to dry enough to put on the second coat. Plus I'm not at all worried about dust or drips.
And for Roc--poly IS varnish.
And one other possibility for the original poster. Use a non-poly finish for a more "in the wood": look than poly will give.
Dry Time
Gretchen -
lightly thinned oil based finishes dry in 4 hours - you can put two coats in one day. That will build a finish quickly + easily as poster is asking. Second day thorough sanding then one wipe on coat to even the finish out.
SA
It is interesting
The other day in another thread I thought some one was saying one thing and it turned out they were saying something else. Now I am seeing a reference to varnish directed at my post. I never mentioned varnish. I did refer to shellac.
I realize Polly is one type of varnish. Thank you for trying to help me out.
I am thrilled to see more activity here on Knots in any case. I noticed there is a double post here. One can not cancel or remove it and the moderator has stopped removing mine when I request it. What I have resorted to now is just putting a period dot in the title field and another in the body of the post just to make it as unobtrusive as possible; that is why you see those in my wake occasionally.
Double Post
You don't use an Apple do you ?
SA
Roc, I'm sorry. I read your post differently and of course you know that. Sorry.
Do I use an Apple ?
Why no. What ever gave you that idea ?
