missing build information in Fortune’s bandsaw dovetail jig
No information on the location of the jig guide runners.
Appreciate some help. Thank you.
Are you referring to this article? https://www.finewoodworking.com/2018/07/26/precise-bandsawn-dovetails
The miter slot is in different places on every bandsaw. So there is no way of providing that information. It should be based on your particular saw.
I have a 14" old Delta with the miter slot running parallel to the blade path. The article diagram shows the runners crossing at about the mid-point of each of the jig fences. Is that all I need to understand?
That should work fine.
Thanks much, Ben.
