Simple question, what side do you use the miter gauge on? I bought a Bench Dog miter gauge and built it according to directions. It’s built to work left of the blade, but I see alot of pictures with the miter gauge to the right of the blade. I own a left tilt TS.
Which way is correct?
Either is correct. Depends on which side of the board you mark and which end you cut off. Sometimes for other reasons, you mark one edge of a board or another.
I generally use mine on the left side of the blade because that's where my on/off switch is and I like to be "close by." But there are times I switch it over -- as evidenced by the two nicks in the pretty gold Incra fency -- forgot to slide the head over!
forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
