Hi All,
What is the smoothest tooth blade for a mitre saw? I get a nice cut on the top and sides but the bottom looks bad, lot of chip out.
Dick38
Hi All,
Dick38
That depends on blade size. I use Freud miter blades, the red teflon coated ones. If I don't cut any metal or particle board with them, I get a year or better from them.
John
One thing that will help is to make a zero-clearance insert for the table. Even with a really good blade, some tearout might occur if there's not enough support underneath the stock.
I'll vote for Freud blades too (I own 3 for the table saw). What size miter saw, and what type of wood or stock (and size) are you cutting???
forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Hi Forest Girl,
I have a 12" slider and cut mostly 3/4" - 4x4" stock.
Dick38
I'm not seeing a 12" CMS blade in the old Freud catalog I have. I'll invite Charles-from-Freud over to give us some help. So, we're looking for a blade to cut 3/4" stock, right? Not 3/4" through 4" I hope, as that's going to cover 2 different teeth-per-blade specs.
Anywho, watch for Charles to stop by.forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Dick 38,
Currently we offer 2 different blades that are ideal for 12" SCMS. The top of the line is the LU91R012. The other is the Diablo D1280S. A google seach should bring up both blades.Charles M
Freud, Inc.
i am happy with the forrest chopmaster.
It leaves a very clean cut. little to no chip out.
I have only the stock blade to compare it to though. never tried the freud.
I swear by my FS Tools 100t 12" mitresaw blade which is on my Makita LS1212 SCMS. Glass smooth.
