I have read articles until my eyeballs are ready to fall out. Through all of that I have not been able to be swayed to any particular miter saw. I build blanket chests. I am needing a good saw and was not sure if a slider was what I needed. It isn’t like your going to purchase this item many times and you want it right. I am looking for streight cutting, smooth and easy use. I want a soft start and need to cut at least 12 inch boards square. I start to think the bosh is boss and then read some of the negative reviews and it makes me uncomfortable. I just need a bit of experiance to help me make that money investement. I am not leaning away from any of them…well…there it is…thanks. I’m not even sure I’m using this area correctly 🙂
Save your misery for something else...
Wood,
This isn't the kind of thing to cause yourself misery over. There are good sliding compound sliding miters out there and there is junk. Stay away from the cheap stuff and the direct drives. Once you're in that class that includes Bosch, Makita, DeWalt, there will be as many arguments for and against each as there are arguments over who was the best center fielder of all time. It's a matter of preference. So as long as you're buying at that level you will be OK.
I have the Bosch 12" Slider and love it.
There are two saws I know of that are outside the norm. These would include the new Bosch that doesn't slide, but collapses and expands on some knid of knuckles (not even sure if it's been released yet.) Then there is the Festool that is a lot more expensive than anything else. Even though I like Bosch, I'm not sure I'd want to be an early adaptor to this new technology, so I would pass on it. As for the Festool... I'd rather buy the Bosch slider and a car with that kind of dough.
Pick a good one and you'll be fine.
Frank
thank you!
I really appreciate you taking the time...alot of help...thank you...like the wisdom too..ha,ha.
SCMS choices
Finehomebuilding did a comparison of several of the leading brands a while back:
http://www.finehomebuilding.com/how-to/articles/miter-saw-features-roundup-video-reviews.aspx
See how the features they show in the videos match up with your personal preferences. Based on those videos, I'd lean toward the Bosch.
I would note, however, that I think of these saws as carpentry tools, where "square" often has a looser definition than in furniture building. Depending on the style of joinery you are using, the level of precision these saws provide may, or may not match your needs.
thank you!
I am grateful for your opinion and it has been a lot of help...have a great day!
Got a Tablesaw????
Add an accurate sled and yur done. If you're cutting long boards, rough cut with a circular saw and finish cut pieces on a sled. Spend some of the extra money on a good plane for a shooting board mebbe? Add some new blades for the TS?
If yur thinking of the Festool, you could prolly take yur significant other on vacation and still have some cash left, LoL.
Circular saws
You raise an interesting alternative, Bob. I always considered circular saws as rough carpentry tools . . . until I succombed to buying a Festool TS55EQ and its guiderail system. Although I bought it for cutting sheet goods, the guide rail provides good accuracy for cutting just about anything, and at about any angle you want. With the long (110") guide rail, one could even use it for building blanket cabins. ;-)
