Hi Folks
I’m starting a project (bar and ent. center) tommorrow and my customer has chosen mitered raised panel doors. This is my first set of mitered doors. My cabinetmaker friend from whom I get loads of good advice, told me he had a heck of a time clamping the miters (reinforced with biscuits) and resorted to the k-body clamp and block setup. $185 ouch!
I’ve been considering splines rather than biscuits for reinforcing the miters but I’m looking for clamping strategies and any other experience anyone would be willing to share.
I’ll buy the clamps if I have to but I can’t shake the feeling that there’s a simpler approach that I’m not considering.
I have 14 doors to make
SJ
sj,
we use upholstery springs or 4" sewer pipe as a mitre clamp.
For pictures of how to, go to the felder site http://www.felder.at and do a search of their catalogue under 'accessories' for mitre or miter (depending on whether you're looking at the English version, or the US English version)
Cheers,
eddie
Thanks Eddie
That looks to be just the thing
SJ
and just another point...
If you want to keep the clamping simple, take the care to make the joints fit perfectly before you put the glue on. Don't create a situation where you need extreme pressure to close a gap.
DR
Back before I had any parallel jaw clamps I clamped up some mitered cabinet doors with a $20 band clamp and corner protectors. Worked fine except you can't really expect it to close up any gaps if your fit isn't right on.
If you build it he will come.
Thanks for your help folks
This is the tool that workrd for me
http://www.rockler.com/product.cfm?page=10401
Cheap and very effective the nuts allow you to direct the clamping pressure right where you need it. I glued, biscuited and clamped tight then flipped the doors over and pinned the biscuits. Then I was able to realease the clamps and go on to the next door. 15 doors in just a few hrs.
I also bought one of the plier and spring contraptions. It worked good for clamping bare miters but would not close the joint with a biscuit in it. I think a frame clamped with these springs and left to cure could then be easily slotted for splines
Was that $20 a corner?
If it was $20 for 4,seems a good buy.
Set of 4 for $20
Hi Sjnkc.
I have a clamp called the Merle clamp . I belive the co i got it from is called MCLS. Ive had it for quite some time before i used it.I am kind of a tool junke, when i see something i think i mite use i will buy it if it does not cost a fortune. That clamp works real good. on doors such as yours. Lay out uour doors on a flat surface then put the clamp on. If i rember right they are a little pricey now,as i plan on ordering a couple more. in the future.
Have a nice day Lee
I make all kinds of mitred raised panel doors and i drill and screw the corners together then glue in a plug of the same wood.
Works great and alot cheaper than buying corner clamp that are limited to size.
Must look into getting a plug cutter for that sort of thing.
Those tapered ones sound the cats pajamas.!
Hi sinkc,
You might want to give this jig a try. I have used it many times and with great success. The nice thing is that it has no size limitations!
Please forgive my artistic talents, or lack thereof, but I think you will quickly get the idea as to how it works.
Make 4 of these fixtures, one for each corner. Then just lay the frame on a flat surface and place the 2 piece fixtures at each corner, leaving a little space for the wedges. Be careful how much pressure you apply when inserting the wedges and tap them together at each corner, making sure that your frame members don't bow.
Please see attached.
Kidderville, NH
Use whatever tool needed to Git 'r Done!
